2007 v36 G35-S with aggressive wheels, Will they fit?
May 1, 2012 | 11:54 PM
I am thinking about running 20x10.5 +15 in the rear. With Camber and a stretched 245/35 tire can I make this happen? I see this is a 10 +18, mean it would poke out 9 mm more than this setup.
Fronts would be 20x9.5 +18. 225/35
Doesn't seem much more aggressive than the white G above on the 19s.
Any input is appreciated!
Quote: you need at least an Eibach drop to make the sizes work with that tire size
this was a photoshoot done with my car with 20x9.5 +25 front and 20x10 +18 rear with 245/35/20 tire all around. I dont know if this helps but i can tell you that your sizes will fit no problem.. oh and to those peeps looking to run staggered wheels on an AWD this setup works wonders, and it wont throw off the AWD system at all. I was scared running 3 different tire sizes for the shoot because we had to drive about 4-5 miles and I thought I was going to mess the car up, but nothing happened
Reply 0
