Fitment gurus...need help 25+ offest on 10 inch wide wheel
Old Aug 28, 2011 | 07:26 PM
Boostd1's Avatar
So I picked up some TSW for a SMOKING deal and I'd hate to get rid of them...however...
I bolted them on the car and they look awesome, BUT they stick out of the fender a good inch...on a 10 wide wheel, would putting a 245/35/20 on it make it look okay because of the stretch?
Help!
Old Aug 28, 2011 | 08:05 PM
B L U E S L A T E's Avatar
Honda Accord
My friend is running the same setup on 245 tires. With coilover, but no camber kit. They look great.
Old Aug 28, 2011 | 08:08 PM
apexi957's Avatar
You'll be fine.
I'm doing a 19x10 all around with +30F and +25R with a 245/35/19 all around.
Old Aug 28, 2011 | 08:11 PM
ChinkyChoy's Avatar
need that drop!
Old Aug 28, 2011 | 08:26 PM
Boostd1's Avatar
Even with the wheel sticking out of the fender??
Old Aug 28, 2011 | 08:27 PM
Honda Accord
When you lower the car with spring or coilover, your suspension geometry allows the wheels to tuck in a little like this /=\.
Old Aug 28, 2011 | 08:29 PM
apexi957's Avatar
What BLUESLATE said! If i'm correct when you test fitted them, you didnt bother putting the car down. Once the wheel touches the floor it'll fit fine.
I fitted a 19x10.5 +12 in my rear and it could've fit if i didn't have 285 in the back haha.
Old Aug 28, 2011 | 08:49 PM
ChinkyChoy's Avatar
when you drop it the wheels will suck in a little basically what blue slate said
Old Aug 28, 2011 | 08:56 PM
Boostd1's Avatar
Well, I had the car jacked up on the frame, then jacked up the lower control arm a bit to mimic the car "resting on the suspension" but IDK...
I'm new to all this stance stuff, I'll talk motors all day but I'm always willing to learn.
Old Aug 28, 2011 | 09:00 PM
Boostd1's Avatar
It's all stock suspension also...
Old Aug 28, 2011 | 09:03 PM
CandlestickPark's Avatar
ill Sedan
Are you planning to run these on stock suspension or are you installing coilovers too?
Old Aug 28, 2011 | 09:05 PM
Boostd1's Avatar
Stock suspension for a while, Eibachs down the road
Old Aug 28, 2011 | 09:22 PM
apexi957's Avatar
You'll be fine if you're on stock suspension. By the time you lower it, you can dial in some more camber or stretch the tires for it to fit.
Old Aug 28, 2011 | 09:37 PM
Boostd1's Avatar
Old Aug 28, 2011 | 09:42 PM
Boostd1's Avatar
^^^ Won't the fender come over the wheel a bit more when the car is lowered off the jack? (still on stock suspension)
