G35 handling
Old Oct 16, 2011 | 10:39 PM
Arielk310's Avatar
G35 handling
Hi, i have a 2008 Infiniti G35 sedan with Jwt pop chargers, resonator delete and Elites Mufflers. i was just wondering what are a few ways to increase the handling of my car? Cheap ideas please!! Thanks
Old Oct 16, 2011 | 11:53 PM
bluestacy04's Avatar
If you search around there is tons of thread about this stuff. IMHO I think you should get some sway bars first. They run anywhere from $250 to $350ish.
Old Oct 17, 2011 | 01:04 AM
JDMPenn's Avatar
I think coilovers (custom settings), sway bars.
Old Oct 17, 2011 | 09:35 AM
rpm&my_G35's Avatar
^ he said "Cheap ideas please!! "
Sway bars, strut brace, coil springs
as mentioned...try searching....there are plenty of discussions.
Old Oct 17, 2011 | 10:56 AM
GXXXV X's Avatar
Look for the thread "GTSPEC explained" ...im not sure if its on here or on myg37 but it is really helpful!
There are cheap pieces that make your car handle better and some are as cheap as 100$!
Old Oct 17, 2011 | 11:02 AM
gary c's Avatar
There's already been two other threads on this very subject this morning....SEARCH! I'll give you a hint, alignment to OE specs and quality tires with a wear rating (UTQG) under 300 will help considerably!
Gary
Old Oct 17, 2011 | 11:34 AM
nawalvicky's Avatar
do a good drop with sway bars and you will be feeling a much better difference right off the back.
Springs $200 Sways $200-250 try looking for used. GL
Old Oct 18, 2011 | 12:49 PM
TomPeters's Avatar
http://www.myg37.com/forums/brakes-s...explained.html
Old Oct 18, 2011 | 01:32 PM
vqsmile's Avatar
Hmm . . . I didn't read through all 10 pages of that thread, but to be honest, from what I did see, I just thought it looked like a bunch of superficial marketing info. While their products may be absolutely wonderful, I didn't see any real technical explanation other than "if you stiffen this part, it will handle better". Just sayin
Old Oct 18, 2011 | 05:08 PM
gtbigup01's Avatar
I had installed some sway bars on my 02 Maxima SE, and swear I saw no difference in handling. What exactiy is the difference you guys claim to see? Wondering if I should try it on the G. Then again I don't drive aggressively anymore so......
Old Oct 18, 2011 | 07:43 PM
vqsmile's Avatar
Originally Posted by gtbigup01
...Wondering if I should try it on the G. Then again I don't drive aggressively anymore so......
In that case, I wouldn't bother wasting your money.
.02
Old Oct 18, 2011 | 08:11 PM
E-Ticket Ride's Avatar
As I told someone in a different thread, if you install sway bars and can't tell a difference, your ***-meter needs calibrating.
Old Oct 18, 2011 | 08:26 PM
vqsmile's Avatar
Unless . . . If you just never even lean into a turn though, your calibration would never even be tested; sways or not.
Old Oct 18, 2011 | 08:49 PM
HeelToeSTi's Avatar
For cheap:
Bushings
Old Oct 18, 2011 | 09:38 PM
True, but then why buy a car like ours, why not get a camry instead? Almost the same hp, prob way more comfortable ride, prob less QC issues too
