RE: 08 Aftermarket Suspension
Old Nov 19, 2011 | 09:43 PM
jbrueggemann84's Avatar
I have a 08 G35x with OEM suspension. I am currently thinking about Eibach Pro springs. With the discount I can get from ordering from work I can get them for less than $300. The front drops 1.4" and the rear drops 1.1". However, I am concerned about camber and the leaning of the tires. Has anyone used these springs without the Camber/Caster Control arms and the rest of the fun stuff you can purchase along with the springs. If you did did you encounter any issues with the aforementioned?
Also, if you have any advice for lowering this particular model it would be greatly appreciated!
My girl just does not get it.
Old Nov 19, 2011 | 09:49 PM
bluedevils95's Avatar
That drop will be fine. anything more then 1.5 your camber will kill the tires. My front camber is -1.4 and the rear is -1.8. I am almost in specs but it's ok at this point. My front really never had a problem. the rear b/c i accelerate fast i lose more rubber. If your worried get a camber kit.
Old Nov 19, 2011 | 09:52 PM
I don't want to have to drop cash on that too if I dont need to. So anything less than 1.5 and I should not get any lean is what your saying?
Old Nov 19, 2011 | 10:01 PM
Your front is fine. i have a rear camber kit that put me back to -1.8 in the rear. i was sitting at -3 in the rear when i did my drop.
Old Nov 21, 2011 | 09:39 AM
Triton3.5's Avatar
Your gonna love the look!! but i am not crazy about the ride after i did mine,,,, I installed a rear camber and toe kit,, also diff. upper arm in front ( camber adustable) so as to not kill my tires. Our winter roads get pretty rough, these cars love winter though!!!
jilljann1
Jul 21, 2020 08:12 AM
nissandrifter32
Dec 22, 2015 04:28 PM
alessandro
Oct 8, 2015 09:29 AM
R350k5
Oct 1, 2015 08:41 PM
