Uh O Door Panel and window track are jacked
Old Dec 17, 2011 | 06:17 PM
Tennessee's Avatar
I need some help. I took the door panels off my 08 Sedan to soundproof the inside of them. I took off the trim panel , then the door access panel with like 12 bolts going around it. 4 bolts(the shiney ones) hold the window track together that raises and lowers the window. After applying the sound deadener, I went to put the access panel back on and the screw holes for the window track won't line up correctly. At first, if I pushed up on the window, and they ALMOST lined up but now they arent even close. Any suggestions?
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
gatorglaze
Sep 10, 2015 12:03 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
will091195
Jul 27, 2015 09:19 PM
