Low RPM @ Idle
Old Jan 9, 2012 | 12:06 AM
07-G35-MT/S's Avatar
Mine does this lately. I thought it may bave been the COBB flash doing it. I have it set for stage 1. I am curious for the fix and hope it is an easy DIY type of thng.
Old Jan 12, 2012 | 07:49 PM
stockae92's Avatar
Anybodyhas this TSB done? How did they fix it? Part replacement? Refresh?
Old Jan 12, 2012 | 08:28 PM
vqsmile's Avatar
Just from reading the TSB, it appears to be only a reflash of the ecu.
Old Jan 13, 2012 | 12:26 PM
stockae92's Avatar
i got in touch with my local dealer and they said the same thing.
i am going to bring the car in these few days to get this done
Old Jan 14, 2012 | 11:51 AM
jbrueggemann84's Avatar
Okay, just returned from the dealership.
Idle relearn and washer nozzle repositioning
Took 2 hrs total will update if issue returns.
P.S. Yay for Infiniti always washing your car.
Old Jan 25, 2012 | 08:09 PM
stockae92's Avatar
got mine done as well. the throttle has noticeable difference in response. Its easier to start and transition between gears smoothly (the ride feel, not the actual gear change).
Old Jan 25, 2012 | 09:22 PM
bwalsh's Avatar
rpm
Same problem with my car. thought maybe cleaning the throttle bodies would work but.... out of warranty any suggestions? start it up when warm and the car drops to 500rpm. WACKED
Old Jan 26, 2012 | 12:53 PM
stockae92's Avatar
I thought TSB are covered with or without warranty?
Or is it only recalls are covered out of warranty?
Old Jan 30, 2012 | 08:40 PM
D/\Rk Stoc|{er's Avatar
Originally Posted by D/\Rk Stoc|{er
I've been noticing the same problem: upon start up and at idle. On start up, my rpms will drop below 1 and sound/feel like it's going to die before returning to normal. On idle, it does same thing if I rev my engine. I have an 08 6MT.
I have yet to take my car to the dealer. Anyone know what's going on?
***UPDATE***
Took my car for service under my Maintenance Package and had them look at the "low rpm" issue. They did two things for me:
1) Cleaned the throttle bodies because there was carbon build up
2) Re-flashed my ECU to an updated software
It worked!! Before, it was difficult to get in first gear, especially going up hills/driveways. I always had to really tap the gas to keep my revs up before feeling safe to let the clutch go. Basically it would stall easily.
But now, I can let the clutch go to a certain point and feel confident the engine will not die. It doesn't have this "shudder" feeling like it used to.
Hope this helps others!
Old Feb 1, 2012 | 10:48 PM
emorehs's Avatar
Hey guys Just a thought I'm having almost the same problem, but mine also the moment I'm going to slow down down My RPM drop then kinda bounce back up a little. And Then when I drive my car for more than 15mins I noticed this Jerk like or hesitate when I press the gas to pass around 1000k. Any thoughts? thanks in advance.
Old Feb 2, 2012 | 12:31 AM
IEMaestro's Avatar
Will the dealer fix this if I'm out of warranty?
Old Feb 16, 2012 | 06:28 PM
tsmehl's Avatar
I'm having the same issue. What's the best way to approach getting this fixed? Should I call the dealer and tell them I am having an issue with RPM dips? I'm worried about haggling with the dealer and them making this a really painful process. I have the extended warranty, will it cost anything?
Thanks for all of the help guys. I'm having the same issue described by others, low RPM at idle and significant dip in RPMs at start up.
Old Feb 16, 2012 | 06:35 PM
stockae92's Avatar
***UPDATE***
did they clean the throttle bodies under warranty or was it an maintenance service?
Old Feb 16, 2012 | 08:22 PM
bwalsh's Avatar
so i took my car to the dealership this past weekend to get this "issue" worked on and according to them they did not notice anything. I know im not imagining things especially when i know my car like i no my wifes A**, Luckily i was only charged the 9 dollars for the rentapiece but still im convinced the TB's need to be cleaned but... oh well looks like im gonna do it myself.
Old Feb 16, 2012 | 08:29 PM
  #30
kool_yaar's Avatar
^yeah TB cleaning is a maintaince thing and not something that would be covered under warranty though these TBs do get dirty quickly, as for those who asked if TSBs are covered under warranty...
Well technically TSBs(technical service bulletins are just meant to tell the dealership techs how to cure a common problem on the car without having to waste their time trying to figure of out the solution) are not recalls so dealers are not bound to do it for free(unless ur still under warranty)and most will charge you for it but some good dealerships value the customer and possible future business and will honor such services for free .
