Exhaust Question
Old Jan 26, 2012 | 10:52 PM
2008G35X's Avatar
Exhaust Question
Hey, Is there any difference in exhaust for an 08 Sedan or an X? I don't think there is but I am making sure.
I was looking at this
http://www.stillen.com/product.asp?i...odel=G35%204DR
Also, ballpark range, how much do you think it would be for install?
Thanks
Old Jan 28, 2012 | 07:55 AM
djfarhan's Avatar
just the pipe layout because the transfer case for the X is different than non X models. other than that, they r the same
and install could depend if ur going to the dealership or a local garage. my shop will probably do it for 150 tops
Old Jan 28, 2012 | 04:13 PM
2008G35X's Avatar
But the the kit from stillen is the same right? And where is ur shop located?
Old Jan 28, 2012 | 08:44 PM
surfjax87's Avatar
Just make sure when you order it you let them know you have an x. The y pipe section is slightly different for the x vs rwd as it has to clear the transfer case.
Install is pretty simple to do yourself if you feel like saving some money. All you need is a couple sockets (14 mm and 10 mm I think), some liquid wrench for the bolts connecting the y pipes to the cats, and a set of ramps or jackstands to lift the front of the car. Took me about 1.5 hours or so to do it myself.
Old Jan 28, 2012 | 09:01 PM
salvador312's Avatar
A RWD sedan exhaust won't fit a AWD sedan!! Give them a call and double check with them. Make sure they send ÿôū an AWD exhaust!
Muski_G
Dec 1, 2023 11:11 AM
Shizzmaster2k
Engine - Exhaust
11
Sep 2, 2015 04:09 PM
gatorglaze
Intake & Exhaust
Aug 17, 2015 02:16 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
