Broken projector housing in headlight! wtf
Old Feb 10, 2012 | 07:49 PM
bat6wc's Avatar
i actually went to replace my bulbs last week and noticed that the entire driver side projector unit broke at the mounting points! the whole thing rattles in the headlight now!! the dust cap pushes the ignitor hard enough into the housing that the housing holds itself but when the dust cap is off, the whole unit is loose. Wondering if the dealer will replace under warranty? I have philips 6000k bulbs in there now.
how does this happen???
Old Feb 10, 2012 | 08:49 PM
mishmosh's Avatar
Replace the bulb with the OE bulb and take it to your dealer. When I still had warranty, my dealer replaced one headlight for crazing. Your issue is much worse so I can't see why they wouldn't cover it.
Old Feb 10, 2012 | 10:32 PM
kool_yaar's Avatar
This is uncommon and crazy for sure but im 99% sure that once the dealer sees you changed the bulb they will some how try to blame you or the blame for the damage saying the bulb installation was wrong/forced causing it or the higher K caused the holding tabs to melt or something(though this is not possible since they generate same heat as stockers)
best way is to pop in the stock bulbs and then try to get them to check it out like mishmosh said.
Old Feb 10, 2012 | 11:56 PM
vqsmile's Avatar
^^ I totally "third" that notion. Put the stock bulbs back in or you just bought the fix.
Old Feb 11, 2012 | 12:35 PM
bat6wc's Avatar
exactly my thoughts as well.
guess i gotta jack the car up and take the wheels off again...
Old Feb 11, 2012 | 12:37 PM
kool_yaar's Avatar
^ i changed mine off without taking the wheel off or jacking up the car, just turn the wheels the other way and pull the liner, its a bit of tight fit but not that bad really and helps you save A LOT of time
Old Feb 11, 2012 | 12:46 PM
bat6wc's Avatar
really? ive been doing all this labor for nothing?
thanks!
Old Feb 12, 2012 | 02:36 PM
bat6wc's Avatar
ok, just switched back to the OEM bulbs, or what I hope are the OEM bulbs. I have several pairs of D2S bulbs laying around, I dont know which bulbs I put in. Anyone have a pic of the OEM bulb?
btw, the method worked but was extremely tight with bigger wheels/tires and lowered suspension.
Old Feb 12, 2012 | 08:07 PM
kool_yaar's Avatar
^ yeah i forgot you were dropped in which case jacking up the car helps a lot but still possible without removing the wheel
Old Feb 12, 2012 | 09:06 PM
bat6wc's Avatar
it saved me 10min probably. almost positive I installed the correct OEM bulbs. hopefully I can drop the car at the dealer tomorrow morning.
Old Feb 13, 2012 | 05:25 PM
bat6wc's Avatar
Just left dealership. Whole headlight replaced under warranty!!
Old Feb 13, 2012 | 05:46 PM
vqsmile's Avatar
^^ congrats!
magnetism80
Feb 1, 2019 10:00 AM
lil beezy
Lights
Nov 16, 2015 02:52 AM
rollaspeed1
Sep 16, 2015 03:10 PM
twentyeggs
Sep 11, 2015 03:58 PM
