How long did your battery last?
Old Feb 16, 2012 | 08:00 AM
g35xdriver's Avatar
g35x
car's stock, no running electronics with engine off. got about 40K/4 years before the battery needed replacing. replaced with an optima red top.
Old Feb 16, 2012 | 12:29 PM
stockae92's Avatar
Is there any sign before the battery crap out? Any "low batt" indicator? haha
Old Feb 16, 2012 | 01:05 PM
rpm&my_G35's Avatar
When I returned my 07X, after 4 years and ~70k km of mostly city driving, the battery showed no signs of degradation. I had no electrical modifications other than adding the plug and play Nissan OEM iPod adapter.
I'm just at 12k km on the new ride and it's been equally as reliable as the X. No issues to speak of, including the battery.
Old Feb 16, 2012 | 01:09 PM
bluedevils95's Avatar
For those who had to change there battery, did you have a problem with the dash flickering gas pedal just didnt work the the car just shut off?
Old Feb 16, 2012 | 02:30 PM
g35xdriver's Avatar
g35x
maybe seemed a little sluggish starting when the temperatures dropped this late fall, but at a recent service check the battery was tested.
no electrical mods, but i do leave an ipod connected 24/7 and am always using it while driving.
Old Feb 16, 2012 | 02:32 PM
mathnerd88's Avatar
Changed the battery out myself- but I had no problems at all.
Are your connections tight? Make sure the terminals are fully tightened so they don't slip off. Someone had an issue with that and the car would shut off.
Old Feb 16, 2012 | 03:27 PM
rvanderwerf's Avatar
sorry if, you can connect a battery tester or bring it to autozone, they can do a load test to it on the spot. Usually that's an indication its toast.. you will notice it has a harder time starting etc, ones a cell breaks.
Old Feb 16, 2012 | 03:45 PM
blkdragn's Avatar
I just replaced mine a couple of months ago at about 75k miles, about 4 years. I added a subwoofer and amp to my stock system but the battery showed signs of needing replacement even before the system.
I changed my battery when i notice the start ups were getting harder and slower. The car was especially hard to start after sitting more than 2 or 3 days.
Old Feb 16, 2012 | 04:24 PM
luger303's Avatar
Second owner, but I believe my batt is the original. Almost 70k on the car. Mostly highway.
this is my next battery. http://www.optimabatteries.com/optim...dtop/index.php
Old Feb 16, 2012 | 09:51 PM
Greenlawnracing's Avatar
When i got a PPI at 3 years and 24k the battery failed the test, but it was $75 to replace under the factory prorated warranty.
Been fine for eight months and 27k, but I would imagine it will slow down any day now.
Old Feb 19, 2012 | 02:27 AM
Afty's Avatar
Heat kills car batteries. My car came from Phoenix, and its battery lasted 3 3/4 years and 63k miles. Totally stock.
Old Feb 19, 2012 | 03:24 AM
JOKER's Avatar
CLUB MODERATOR
I have 123k on my coupe. Original battery. Will replace it soon tho.
Old Feb 20, 2012 | 10:23 AM
Jayhawk815's Avatar
My G is 4 years old and sitting at 40k miles. I believe my battery is starting to tank. I have stock electronics, and have only run just battery a few times, far less than I have with any previous vehicle. One time I did leave it on too long, requiring a jump start. I didn't keep track of exactly how long, but didn't seem all that long though. Just recently, I didn't drive my car for 3-4 days, and the battery was dead when I finally went to start it. It also seems a little sluggish on startup at times.
For the ones that have replaced their batteries, did you go OEM or aftermarket?
Old Feb 20, 2012 | 10:31 AM
You would get one of those lightweight odessy batteries, would shave off 20lbs easy I just got a costco replacement, you can't see it anyways under the cover, and it was only about $68.
Old Feb 21, 2012 | 12:45 AM
  #30
Afty's Avatar
Costco battery for me too. They're very well reviewed and reasonably priced.
