Sunroof won't open
Old Mar 23, 2012 | 06:32 PM
Mike75's Avatar
Sunroof won't open
Any1 have this problem: My sunroof, when I try to open it will sound like the motor is running through a complete, normal cycle, but it's not moving the glass.
It's stuck in the closed position luckily.
Maybe it became detached from the mechanism?
Would it be possible to take down the headliner and reconnect it or would that be difficult to make it look like it was never down(sagging, etc.)? TIA
Old Mar 25, 2012 | 03:29 PM
Solo G's Avatar
Ive never had the sunroof stuck closed, but its been stuck in the vent position before. When I pressed the button to close it, the motor would start but then it would kind of stall out the way your car will stall if you rev a manual into redline. Took it to the dealer and they said that ALL the screws that hold the motor up had come loose and the gears of the motor werent in contact with the gears that slide the glass.
Old Mar 25, 2012 | 07:47 PM
kool_yaar's Avatar
Iv seen a couple of ppl with this problem here on the forums and like SoloG said the screws came loose which apparently are very easy to re-tighten by pulling the liner a little form the sides without having to remove the entire thing
Old May 1, 2014 | 10:18 PM
kelvin21's Avatar
help sunroof problem
know this is an old topic but im currently experiencing the same problem u had my sunroof wont open but i do hear the motor trying to open how dud u fix the problem and what was the problem
Old May 1, 2014 | 10:37 PM
Solo G's Avatar
Sounds like the same problem that I had and many others. Screws most likely came loose from the motor and its hanging below the gear mechanism to move the glass. If you pull down the headliner you can get right at the screws and secure them with some loctite to keep it from happening again
If you don't want to tackle it, your local dealer should be able to do it for free or cheap. It takes like 30 min max to do
Old May 1, 2014 | 11:04 PM
kelvin21's Avatar
thanks ill give it a try if not ill just bring it to the dealer
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
BradMD_96
Oct 6, 2015 09:31 AM
Claudiu
Sep 26, 2015 01:04 PM
