Who did Non-Foulers for SES light after HFC installation??? jump in!
Old Apr 25, 2012 | 07:10 PM
Shurik355's Avatar
Alright I installed my DIY non-foulers and the SEL light popped up again the next day!!! that DIY is actually crap!!! doesn't even work and fit right for our O2 sensor Gs!
Any idea where I can get the real NON-foulers??? something that will fit our Gs and our O2 sensors.
PPL with HFC and who got cel!!! what did you do?? how did you fix your problem???
Old Apr 25, 2012 | 09:43 PM
seymore4's Avatar
m56
never heard of putting steel wool inside, I had them with my fast intentions HFC's when I was NA and still threw a CEL, got tuned with Osiris and just turned the code off, lol best way to do it IMO
Old Apr 26, 2012 | 07:28 PM
Shurik355's Avatar
Yeahh I read about this steel wool and it works 100%. Lot's of Z guys do it!
Old Apr 26, 2012 | 07:30 PM
Shurik355's Avatar
Come on someone did this Im sure! Im not the only one who runs HFCs with popped SES light.
Old Apr 26, 2012 | 07:40 PM
seymore4's Avatar
m56
Did you ever try it yourself?
Old Apr 26, 2012 | 08:14 PM
kool_yaar's Avatar
steel wool is pretty common in HFC and TPs on which the extenders arent enough to avoid the SES. There is a diy on myg37.com (or here) and following that DIY should tell u exactly what to do. I know for sure there was a DIY on adding extenders with some steel wool stuffed in it to get rid of SES on HFCsbut just cant to find it now... maybe someone has it bookmarked and can post link to it.
But THIS one is a nice one as well using just extenders and it seemed to work just fine.
Old May 7, 2012 | 08:37 PM
Shurik355's Avatar
Old May 7, 2012 | 08:51 PM
seymore4's Avatar
m56
Mine were throwing a cel but I got an Osiris tune and just turned off the code in the
Tune, I think that's what most guys do
Old May 7, 2012 | 10:18 PM
daniel2288's Avatar
what happens when you need to go in for emissions?
Old May 7, 2012 | 10:27 PM
Illuminati's Avatar
Depends from state to state but overall if there is no CEL present your car will pass inspection but could penitential fail visual inspection.
Old May 7, 2012 | 10:28 PM
seymore4's Avatar
m56
you pass
Old May 7, 2012 | 11:42 PM
Shurik355's Avatar
yeahhh heard about that Osiris ECU tune! I was actually thinking about doing the same. Need to do more research on it! I know it's not cheap! so i hope the HP numbers are also worth it!
Old May 8, 2012 | 12:12 AM
seymore4's Avatar
m56
Actually for the increase in performance, reliability and overall drivability I'd rank it at almost #1 in proven and worthwhile mods. Depending on how you go about it it will set you back anywhere from 400-800
Old May 8, 2012 | 07:19 PM
Shurik355's Avatar
wow really huh? definitely looking into it now! Any ideas where I can buy Osiris for the best price?? I already know a guy who can do the tune for me when I get it.
Old May 8, 2012 | 09:05 PM
seymore4's Avatar
m56
I'll PM you.
