Help! I cant figure out whats wrong?
Old May 13, 2012 | 04:01 AM
RelliKg35's Avatar
i replaced the cap today, so we will see if that fixes it. One thing i did notice on my car is on the overflow tank i am missing that small hose connected to the nozzle. Where does this hose lead to? *Picture isnt my car* just using as a reference for the hose im talking about
Old May 13, 2012 | 12:08 PM
vqsmile's Avatar
LOL, if you're missing that hose, then there's your problem right there
There has to be a hose that connects from the radiator (or gooseneck) from right below the cap over to the reservoir. If you are missing it, then your radiator will just dump the coolant instead of passing it to the reservoir. The coolant needs to be able to flow back and forth between the radiator and the reservoir for normal operation.
Edit: I was referring to the hose between the reservoir and the radiator (obviously), but here is also another hose attached to the reservoir in that picture (toward the front and bending downward). That hose is to direct the overflow in case the reservoir overfills. It is not critical, it just directs the overflowing coolant neatly, so that it doesn't make a huge mess in the engine compartment if it overflows. It typically is routed down low and is left open to dump under the car.
Old May 13, 2012 | 05:42 PM
RelliKg35's Avatar
I'm referring to the small hose that is by the shroud not the hose near the radiator cap. So that hose I'm talking about is not necessary?
Old May 13, 2012 | 11:34 PM
vqsmile's Avatar
No, it's not required. I'm 100% sure it is just to plumb the overflow. But with that being said, you still ought to get one just so that it doesn't make a mess if it overflows. I really don't understand how yours could be missing. The hose is quite firmly attached in numerous places and would take quite a concentrated effort to remove it completely. You'd pretty much have to do it on purpose; they won't just fall off. Has someone worked on your car?
Old May 14, 2012 | 02:10 AM
RelliKg35's Avatar
yea the person i bought the car from wasnt the best owner. Another thing i keep noticing is white smoke coming out of the exhaust. not a crazy amount but a constant flow of it.
Old May 14, 2012 | 02:25 AM
vqsmile's Avatar
UHmmm ...you never mentioned THAT little tidbit. You could very well have a blown head gasket if you're constantly blowing white smoke.
(btw, I now have a pretty good idea where your missing coolant went)
Old May 14, 2012 | 05:35 AM
RelliKg35's Avatar
first off thanks for all your help on this manner I have only started the car like 3 times after this incident and i dont know if maybe the white smoke is condensation or coolant. I checked the oil and its not milky at all, and the car runs totally fine. i will probably just take it to infiniti this week and get a diagnosis.
Old May 14, 2012 | 10:34 AM
ProKiller's Avatar
if you're also getting white smoke from the exhaust then it usually means its a head gasket. basically the coolant was blowing out because the system was getting pressure from the combustion chamber. it might only be a small leak and it wouldn't drain into the oil.
get a coolant pressure test done.
Old May 14, 2012 | 11:55 AM
vqsmile's Avatar
Unless it pretty cold where you are, then your car should not be making any condensation for more than a minute or so. If it is doing it after it's been warmed up and running a while, then there's definitely a problem. Good luck and please let us know what it turns out to be.
Old May 14, 2012 | 12:33 PM
RelliKg35's Avatar
Anyone have a clue on how much a headgasket repair will cost? Easier to buy a new motor? Why would this happen? The car has never been overheated and only has 91k on it
Old May 14, 2012 | 12:57 PM
b-dRizZy's Avatar
highly doubt youll need a new motor. could be something small,
im in for more on this my G is at 90k now havent got any type off this problem before ;/
Old May 14, 2012 | 02:32 PM
ProKiller's Avatar
but you don't know that it's never been overheated. you said yourself the previous owner wasn't the most diligent with the car. and just overheating the car doesn't mean you're going to pop a head gasket. it just generally leads to warping heads which in turn allows for a weak/low pressure spot in the gasket surfaces.
regardless, until you have it pressure tested, no one can really say conclusively that is the problem.
Old May 14, 2012 | 02:56 PM
RelliKg35's Avatar
Just had it pressure tested and it passed. Compression is fine. Im puzzled and happy at the same time. mechanic said overflow was probably just overfilled and spilled out.
Old May 14, 2012 | 04:15 PM
b-dRizZy's Avatar
i bet thats a relief lol .. ^ .. its like weather you pull the plug or not lol ..
Old May 14, 2012 | 05:12 PM
  #30
vqsmile's Avatar
Hmm, I'm crossing my fingers for you that that is all there is to it, but I'm still concerned about the white smoke. Did the mechanic have any explanation for that?
