Finally a real clutch fix for the V36 sedans
Yesterday I installed a RJM Performance adjustable clutch pedal bracket in my car and my car is finally shifting like it should. The bracket completely gets rid of the factory clutch pedal along with the spring and damper that make the clutch almost impossible to modulate well. It's a lot easier to push the clutch in, and it's also adjustable so that you can manipulate how much pedal travel there is between full engagement and full release. It's been available for the 350Z and V35 coupes and sedans for a while, but now there is a new version for the V36 thats easier to adjust.
It took me about 2 and a half hours to install, and most of the difficulty was maneuvering in the footwell under the dash. (I'm a bit more sore than I'd like to admit this morning) I wouldn't say this is a good first project for someone, but anyone with some mechanical aptitude and experience shouldn't have any trouble. No special tools are required, and nothing is cut or modified making this easy to reverse if you ever have to sell the car to someone you hate. The instructions are very good, and nothing other than normal metric hand tools (wrenches and ratchet with a swivel) was needed. Everything fit perfectly. This piece was very well made and uses the stock mounting points, and the stock pedal cover. It's better than the clutch pedal that came with the car in every way. I installed it at the recommended adjustment position, described as 70% in the installation guide and after an extended drive this morning I didn't feel the need to adjust it any more. I want to spend some more time driving with it and getting used to having a 'normal' clutch again. I know this has probably been mentioned in other forums, but since I pretty much only read this (v36 sedan) section and I hadn't seen it mentioned before I thought I'd post here. |
wheres the link to it?
Good share and glad to hear youre happy with the mod and should help a few folks around here a lot, but honestly speaking the stock clutch system with the spring removed is not as horrible imo as you think after you get used to it :)
Originally Posted by Highestrich4
(Post 6492721)
Originally Posted by kool_yaar
(Post 6492730)
I think with Intg8r's 2 clutch fixes, the clutch pedal feels totally natural and is exactly what I expect it to feel like. I don't know what too much "play" in the clutch pedal means. I don't think there is a lot of pedal travel between clutch takeup and full release. In fact, it's pretty short compared to a lot of cars.
Originally Posted by mishmosh
(Post 6492934)
I've driven manual transmission cars for over 25 years and I still felt there was room for improvement over the spring mod. It's not for everyone; removing the spring might be enough for some and a lot of people think the clutch is fine the way it comes from the factory. |
(Post 6492934)
I think part of the issue is with the clutch slave actuator and is why there is a variety of results & impressions (good bad & otherwise). The OP's pedal find does look really good though :JAMIN: |
hmm...this is very interesting to me as I feel our clutch engagement is much too quick. I have gotten used to it over the years but still find it difficult sometimes.
I got the weaker spring someone here and on myg37 is selling, I installed it last weekend, it seems a litlte better. If it's still really bugging me after a couple weeks I'll look into the rjm one. I definately would stall mine once a week if I've driving a lot because of it.
Just installed the RJM bracket this morning. Took me a little longer than 2 hours, but the instructions are very thorough.
Prior to that I had the clutch spring removed and 4 nickels taped to the stop and switch to reduce the engagement distance. With the RJM bracket it is a night and day difference. Even with the spring removal and 4 nickels, there were times where I had to really concentrate to drive smoothly like on a steep ramp. I mean I had to turn off the radio and use all my senses except for taste to be able to consistently get out of 1st smoothly. The RJM bracket was well worth it. I have it at 70% for now. Not sure if I'll try to fine tune it but it's super easy to use the dial. |
