when looking up brake pads...do I get pads that are for the Sport or base. I would assume base right?
kool_yaar
close
- Join DateOct 2007
- LocationSomewhere
iTrader Positive Feedback100
iTrader Feedback Score(7)
Liked:185 Times in 160 Posts
yup they should be the base pads, best way is to look at your front calipers and if they are one big piston (u see one big half circle vut in the middle of the caliper like THIS(not G)) you have sports, but if you have 2 pistons then you have base(two half circle cutouts on the face of the caliper like THESE)
kool_yaar
close
- Join DateOct 2007
- LocationSomewhere
brake pad changes are the same on most cars, the DIY should work fine except that some bolt sizes or the bolt type might be different but same procedure should work fine
