Help please!!!!!!!!!!!!!!
Old Jul 6, 2012 | 11:12 PM
Lexoes350's Avatar
So long story short I got rims from my friend and they were suppose to be 20x8.5 the front +35 offset and the rear 20x10 the thing that sucks is all tires were mounted on these rims. So their ended up being 3 20x10 and one 20x8.5 so I ended up just ordering another 20x10 because I loved how deep the dishes were is their anything bad about running 10s in the front and also will I still be able to lower my car?
Old Jul 6, 2012 | 11:24 PM
kool_yaar's Avatar
whats the offset on the 20x10? it should be fine in the rear but the front im not sure if it'll work properly without any rubbing with the liners or fenders, im no expert on this subject but its not hard to calculate this stuff, read soundmikes DIY on measuring this kinda of stuff for fitment in DIY section i believe, but post the offset and im sure we can tell you with more assurity.
Old Jul 6, 2012 | 11:26 PM
apexi957's Avatar
You can run a 20x10 all around easily. +25 fits in the rear perfectly and you can run a +25 up front, but you have to roll the fenders
Old Jul 6, 2012 | 11:29 PM
Lexoes350's Avatar
Offset for front is +35
Old Jul 7, 2012 | 11:56 AM
rpm&my_G35's Avatar
A bit OT but why not order another 8.5" wheel? You where initially going to run staggered. Is your G an X?
Are all 4 tires the same width too? 275 or 285
Old Jul 7, 2012 | 01:50 PM
Lexoes350's Avatar
I ran a 245/35/20 stretched on the three I have now I don't like the 8.5 due to the small lip on it that's y I went wit the ten but I wanna do coilovers on my car As well the tens in the front clear and don't rub whatsoever I think it would rub if I ran a 275 idk if I can get some more opinions/ suggestions I might just order the 8.5 too just to be safe for future
