What is the best way to add sound when I am rubbing the engine
Old Nov 15, 2012 | 04:58 AM
300zx69's Avatar
I have a 08 sedan stick shift. I don't care about gains just some deep sound. What do u guys suggest. Thanks
Old Nov 15, 2012 | 07:05 AM
sgtschulze's Avatar
If you are "rubbing" the engine, you're doing it wrong! lol
Old Nov 15, 2012 | 09:11 AM
alej's Avatar
I would rub it with something that will make a lot of noise against aluminum. I think for a deep sound you will want to go with a large hollow pipe. The thickness of the pipe wall will change the sound some, so you will want to experiment. You may have to tap more than rub for a deep tone. A deeper tone tuning fork may work if you can find one.
Old Nov 15, 2012 | 12:12 PM
RedBaronK's Avatar
What in the hell is rubbing the engine mean???
Old Nov 15, 2012 | 12:17 PM
Shanes_G's Avatar
I think you should tap it first with a long solid pipe. Then poke it and rub it at the same time. Anyone?
Old Nov 15, 2012 | 12:58 PM
300zx69's Avatar
Lol. You guys are funny. Never heard of that huh. I meant when I press the gas. Intake is one of my choices but it will cost around 400. Anything else I could do since all I want is some sound coming out. Thanks
Old Nov 15, 2012 | 01:08 PM
KrazySouthG35's Avatar
Intake won't make much of a sound difference. You're looking for exhaust
Old Nov 15, 2012 | 01:09 PM
Glex25's Avatar
Administrator
HFC are the way to go if you want a deeper sound
Old Nov 15, 2012 | 02:02 PM
300zx69's Avatar
Great choices but I don't want to spend 500 on just sound. Any other cheaper options
Old Nov 15, 2012 | 02:08 PM
botlfed98's Avatar
rubbing = revving??
rpm&my_G35's Avatar
Muffler delete = free
http://www.myg37.com/forums/g37-seda...ete-video.html
Old Nov 15, 2012 | 02:12 PM
My custom y pipe back was only $200 with a magnaflow mid pipe and muffler delete
Old Nov 15, 2012 | 02:40 PM
saywat?'s Avatar
lmao @ rubbing the engine
Old Nov 15, 2012 | 09:27 PM
RedBaronK's Avatar
Jesus.. without the mufflers it sounds like a damned cheap *** honda ricer car
Old Nov 15, 2012 | 10:16 PM
vqsmile's Avatar
