Question on Sound....?
Old Mar 17, 2013 | 12:15 PM
xWKUJoBo36x's Avatar
Hey guys I'm new to the G community, just picked up a 2008 G35x with a little under 70k miles on it.
Just a question... When I'm driving from 0-30mph the car is making a weird sound not really a screech but it sounds like metal is rubbing on metal. It sounds like it's coming from the front drivers side but it's hard to tell since I can't really hear it unless I'm driving. Do you all have any ideas? Thanks!
Old Mar 17, 2013 | 12:33 PM
matts08x's Avatar
Is it under hard acceleration? Like at a shift point? From what you're describing, I'm assuming not, but if it IS at a shift point under hard acceleration, it's kinda normal, unfortunately. An odd noise that the cars make.....normal, though.
Old Mar 17, 2013 | 12:45 PM
No not under hard acceleration just normal really, it's pretty weird because it's like a screech but not really. Like I said it's hard to describe it just sounds like metal is running against metal and making a high pitched noise
Old Mar 17, 2013 | 12:46 PM
Rubbing****
Old Mar 17, 2013 | 07:36 PM
dukehotty's Avatar
Is your car dropped? Could be your tires rubbing the fenders.
Old Mar 17, 2013 | 10:23 PM
mathnerd88's Avatar
It could also be your splash shield on your rotors rubbing against the rotor...
Old Mar 18, 2013 | 01:24 AM
vqsmile's Avatar
First, I would make sure your front brake pads aren't worn down to the rivets, and/or the caliper is sticking. Then I would look for an issue with the rotor shield (as mathnerd noted) either rubbing the rotor OR as sometimes happens, a small pebble can get lodged between there, causing a noise. I guess it's also possible it could be a wheel bearing noise.
Old Mar 30, 2013 | 05:44 PM
Jmforgey's Avatar
The only metal screech sounds I've had on vehicles were the result of bad brakes or wheel bearings. Given your year and mileage, I would lean more towards brakes. Can you have someone stand outside the car while you drive by on either side? Maybe they can pinpoint the noise location better that way?
A lot of shops will do a free brake check with oil change... may be worth looking into.
Old Mar 31, 2013 | 03:56 PM
RedBaronK's Avatar
This is only whole moving right? Not when parked and idle?
Noisy AC compressors are common with 08...but it's more of a mechanical sound and not rubbing metal on metal
Old Apr 4, 2013 | 07:14 PM
08infinit's Avatar
Wheel bearing?maybe
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
