Front Console Power outlet Not working
Old Jun 7, 2013 | 02:06 PM
Feeelax's Avatar
Hello forum. I need some assistance please! The front power outlet is not transferring any power to my devices. The outlet in my center console is working fine. Would this be a fuse problem?
Thanks
Old Jun 7, 2013 | 03:55 PM
Feeelax's Avatar
Changed fuse and it just keeps blowing. Any ideas?
Old Jun 7, 2013 | 04:02 PM
GR6RR's Avatar
something is touching, shorting it out. maybe check the two wires going to the outlet. Might have to take the dash apart.
Old Jun 7, 2013 | 04:54 PM
Solo G's Avatar
I dont have any suggestions for a fix (sorry) but I have the same problem. I just gave up on it since I mainly was using the one in the armrest anyway.
Old Jun 7, 2013 | 05:50 PM
Feeelax's Avatar
(After changing the fuse) Initially when I plug something in, it receives no power until I wiggle my charger around then it will light up however, I have to hold it in a specific spot. I let go and try a few more times only to blow the fuse again. I've blown a couple now.. My guess is maybe the insert/sleeve of the outlet is defective. Anyone familiar with the detachment of the insert/sleeve and to plug a new one.
Old Oct 1, 2013 | 05:09 AM
kenasaki's Avatar
Sorry for raising this thread from the dead, but can u please tell me where the fuse for the center console power outlet is located? It's never worked and I would like to finally fix it
Old Oct 1, 2013 | 12:47 PM
stockae92's Avatar
The owner's manual should have that
Old Oct 1, 2013 | 06:48 PM
Feeelax's Avatar
Its within the driver cabin. Look on the lower left side/close to the floor. Theres a compartment there. Open the cover and there should be a whole bunch of fuses there. You need swap the blue fuse. Look on the cover it will tell you which fuse is responsible for what.
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
newg37
Jul 26, 2015 09:32 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
