View Poll Results: Should I keep the extended warranty from AUL?
Yes - have heard that it needs atleast one major repair in 5-10 years or around 100-120k miles
14.29%
Multiple Choice Poll. Voters: 7. You may not vote on this poll
Extended warranty question - Purchased an 08 G35X Sedan !
Hi guys,
I purchased an '08 G35X Sedan last week. It has 79.5k miles on it. I bought from a Chevy Dealership cos the price was lesser there..(so obviously no inspections were done on it ) I purchased the extended warranty from AUL through my credit union. It costs me 2806 with 0 deductible and is valid for 5 years and 50k miles. Its supposed to be their highest "bumper to bumper" sort of plan.
It bumped up my monthly payment by 55 dollars! Guys, do you think its worth paying the $ 2806 ? Are there any known / common issues with the G35X Sedan. Having gone through the fine print back at home, I am appalled by the number of exclusions in the "Bumper-bumper coverage". Though originally they stated they cover wear and tear- they have excluded all the parts that can possibly wear and tear! And looks like, dashboard electronics is not covered either.
Are there any issues which people have been facing with the 08 G35X Sedan...like any water pump, timing belt replacement? On my car I already noticed the steering skin is peeling off, the coating/paint on the door handle is kind of stripped off and on the inside of the door- the paint/coating is worn off near the buttons. But none of these are covered obviosuly!
Guys
- do you think I am better off saving that 2806 and cancelling the plan in the next 60 days? I purchased a used car with 79.5k miles for saving money at first place!
Guys
I vote other.
I did one of these on my Jeep SRT8. They said that my condition was pre-existing to buying the jeep (even though they didn't check it over or anything) and refused to service my car under the warrantee.
Replace things that break with better aftermarket stuff.
treacherous - It has Nav and premium package..I originally thought it had tech package, but then I don't see the AFS switch shown in the manual.. so that was a bummer!
The dealer said, fully loaded with all options..and I didn't check further before i bought. It was a chevy dealer and probably he didn't know either.
jtrain - thanks for your input on the jeep. I also have a CR-V, bought it pre-owned. Did not opt for Ext. warranty and well, I assume honda parts would be cheaper than Infiniti.
I voted to cancel the warranty. Not many reports of G's needing major repairs until well after 100K on here, but obviously there are some. My 05 has 122K and I've spent around $600 on repairs other than routine maintenance and the repairs were expected (lower control arm bushings and lower ball joints) with my mileage. These cars will last a long time on average if they're taken care of.
When I bought my '08 pre-owned, I opted not to get the extended warranty (at around $2800 I think) because part of getting a Japan made car is that it *should* be more reliable.
Having said that, you can't say 100% that nothing major would go wrong within the period of the ownership. Having something goes wrong without an extended warranty is always a risk. Its how much you think its worth it to you.
If you keep up with the maintenance and drive the car within reason, then you may lower the risk of something major going wrong. But nonetheless, the risk is there.
I appreciate your inputs! So,. if there were repairs.. how expensive are we talking about.. far more than say, a Honda or Toyota will cost? I know it depends on what part if brokenm, but still.. for the same part, is Infiniti part way costly?
I would like to save that 2806 and possibly set it aside for repairs myself- but then, this is my first 'premium' car
.. and I will be darned!
When I had my 07' G (traded it in for a 328i), the powertrain warranty was still in effect for about a year (expired August of this year, 2013).
Made quite a substantial use of it for the following:
- New Transmission: old one was slow to engage reverse and drive, would lurch into gear sometimes.
- New front wheel bearings: made noise, common issue.
- Thermostat and Radiator fan module: overheated due to some malfunction. Was towed to dealer.
- Catalytic Converter: One of them was not working effectively, so got a new one.
All of this happened during the period of May to July. I know these are reliable cars, but mine wasn't so... But it was a joy to drive around in! Would have kept it a lot longer if these problems didn't surface... (overheating and catalytic converter)
But in the end, en extended warranty isn't worth it. You'll probably be able to save enough for when repairs surface. And most cases, you won't be able to get the full value of the warranty.
Im at 105K and running strong. Best car ive ever owned. Only problem was an axle leak at 60K and wheel bearing at 80k. But im selling mine soon and getting a BMW. I got a job with BMW so...... its time.
I also have the Elite warranty, paid about $1800, and have about another 45K miles, 3 years left on it. They replaced 2 TPMS sensors and the sunroof rubber trim as well. I believe it's worth the money, but I haven't had any major issues yet - fingers crossed -
I tried to get that lining on the outside of the sunroof replaced (as it's beginning to crack), as well as other trims like steering wheel and door trims, but was denied.
