Need help with 07 G35X Sedan AWD Springs
Old Nov 24, 2013 | 01:51 PM
seva252's Avatar
I been looking to find some lowering springs for G35X Sedan AWD 2007 model can't seem to find any they all say (EXC 4WD) not sure what that means but I'm looking for a mild drop after i put on 18" 245 from stock eve rims now just need the drop. I heard S Tech is pretty good but the same problem can't seem to find any for my model any help would be appreciated i got this car not too long ago so I'm still new thanks.
Old Nov 24, 2013 | 11:34 PM
blnewt's Avatar
S Techs are a deeper drop, not sure if they make them for an X, for a milder drop check Swift springs, here's a good thread on them~
https://g35driver.com/forums/g35-sed...t-springs.html
Old Nov 26, 2013 | 11:31 PM
SlimTV's Avatar
Swift springs!
Old Dec 3, 2013 | 09:31 PM
beto4632's Avatar
I'm thinking of ordering my own for my 07 G35X eibach 6383.140 pro performance spring kit. It runs for about 230 and looks great.
Old Dec 5, 2013 | 09:43 PM
xcelocity's Avatar
I just went through this recently. Swifts and eibachs are the only two lowering springs that officially work with awd. Eibach's drop a little lower than the swifts. I went with eibachs and they look and ride great. But my camber ended up being -2 degrees or more at each corner with no adjustments left so I ended up installing spc front and rear camber kits. It would've been easier had I done it at the same time I did the springs.
Old Dec 6, 2013 | 12:09 PM
Mustang5L5's Avatar
they all say (EXC 4WD) not sure what that means .
It means "Except AWD"...in other words it won't work for you
Cajuncowboy
Jun 21, 2021 09:47 AM
reavensf
Sep 17, 2015 11:30 PM
Srinidhi
Aug 7, 2015 03:38 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Scredeur4
Jul 17, 2015 06:30 AM
