I searched and didn't find a specific answer, but does anyone know if I can swap G37 headlights onto my G35? Anything else required to be swapped as well?
Thanks!
Thanks!
Quote:
Thanks!
Do you have a sedan or a coupe?Originally Posted by samuel1021
I searched and didn't find a specific answer, but does anyone know if I can swap G37 headlights onto my G35? Anything else required to be swapped as well?Thanks!
If you have an 07+ sedan, then yes, you can swap them for 2010+ headlights....you need the grill and front bumper to go along with the swap.
If you have a 35 coupe, no, you cannot swap the 37 coupe headlights without some serious body work.
I've done the swap. You need the bumper, a new washer bottle, new grille, new fog lights, fog light grilles, bumper impact bar, and seal strip. Everything is bolt on.Originally Posted by chilibowl
Do you have a sedan or a coupe?If you have an 07+ sedan, then yes, you can swap them for 2010+ headlights....you need the grill and front bumper to go along with the swap.
aktif8, Wasup man, I'm currently purchasing all the parts to do the G35 sedan to G37 journey swap. Is the impact bar necessary along with the energy absorber (Styrofoam ) as well? Thanks
Sorry, semantics. It's just the Styrofoam piece that's necessary, not the metal support behind it.
Btw, I'd highly recommend opening up the headlights and doing 180 style evil iron man leds. More so than the conversion, those get more positive comments then anything else on my car. iirc, I posted a pic after I did mine, here or on myg37.
https://g35driver.com/forums/media-share-v36-sedan/432840-aktif8-s-08xs-build-thread.html
Pic after 37 sport conversion
