I am likely to go square due to awd and wider than stock very slight stretch, but not a fat tire look either.
Want to be able to rotate as well.
Quote:
Yea I did. The offsets are 20. Rim 19 x 9.5 all around. Square set up. Originally Posted by epborden
.......By the way did you post the offsets you chose?
@rich2342 i went squared cuz of AWD as well. I wouldn't mind a stretched tire look, a subtle stretch though. Not that 205 on a 9in rim look
8.5 front and 9.5 rear are my wheel sizes. What wheel size, offset, and tire sizes did you start with?
Quote:
Cool, with that in mind the tire sizes you should choose are:Originally Posted by Peepz
I started with stock. 225/55/17 et45 8.0 wide
Tire size: 245/35/19
Diameter: +25.2mm difference
Speedo: +3.85% or +2.31mph over actual
Stretch: Heavy
Tire size: 255/35/19
Diameter: +18.2mm difference
Speedo: +2.75% or +1.65mph over actual
Stretch: Moderate
Tire size: 265/35/19
Diameter: +11.2mm difference
Speedo: +1.68% or +1.01mph over actual
Stretch: Slight
Tire size: 275/35/19
Diameter: +4.2mm difference
Speedo: +0.62% or +0.37mph over actual
Stretch: None
Really appreciate the help with those links. Thanks. I was thinking 245/40 since i have AWD and have to keep the rolling diameter the same and the stretch should help with rubbing.
Quote:
Those sizes I gave you take that into consideration. 245/40 would be about as perfect as you can get but you're going to stretch a bit. Originally Posted by Peepz
UPDATE:
Had to quit my job recently due to scheduling issues with my school so my purchase for tires are currently on hold so any update pertaining to the wheels will be pretty much stagnant from this point on.
I do have my coils and journey lip to install so yea.........is there a build thread section?
This is more of a "I installed my coils and lip" update rather than what the topic title says. Sorry but i think she looks sexxxyyy!!!
I'm raising it up about an inch tomorrow as i can't take my paranoia driving around these NY roads.
I smacked my sub frame nice and hard on a dip i didn't see. Broke necks all around town tho I think they only looked to see who the hell was scraping.lol
I smacked my sub frame nice and hard on a dip i didn't see. Broke necks all around town tho I think they only looked to see who the hell was scraping.lolSo i finally put them on......a month ago but i've been lazy so here she is with them on. Took long enough. Thank you modbargains and thank you friends and family for the graduation gift wich were my tires
No rubbing in the rear and slight rubbing in the front every now and then. Gotta get the fronts rolled and then lower it a bit more. Next up is a G37 conversion
Blue Dream
I drove ttrank's car solo
close
- Join DateMar 2009
- LocationBy the sea, Tx
iTrader Positive Feedback100
iTrader Feedback Score(50)
- My RideG35 sedan w/ too much money in mods
Liked:1,488 Times in 1,223 Posts
Wheels look good and fitment is spot on. Great job.
