A hundred thousand kilometre service.
Old May 14, 2014 | 12:54 PM
SofaKingAzn's Avatar
I have a 07 G35x gonna be hitting the 100000 kms soon. What should be serviced and changed at this point? I'm planning to change the brake fluid, coolant, transmission fluid, differential fluid, steering fluid. Things like brake callipers, brake pads, rotors, engine oil/filter, air filters I've been changing regularly. What else am I missing? thanks!
Old May 14, 2014 | 09:44 PM
stevesg35's Avatar
Only extra things I can think of if you like are transfer case fluid (Matic D) front differential fluid as well as rear (both gear oil) and perhaps the two drive belts. I think there are two belts for '07 which went to one serpentine belt for '08. Think so anyway. The belts likely go 100k and maybe longer but it's cheap insurance while you are in the shop.
Marlin84
Apr 1, 2020 12:52 PM
f22raptor
Mar 18, 2016 08:50 AM
TNRocker
Sep 21, 2015 08:36 AM
