i have 2 easy questions if you guys could help
Old May 16, 2014 | 09:50 PM
youngdip631's Avatar
hey guys hows it going, i have a 07 g35x sedan and on the interior right about the glove box below the rosewood trim the clear strip is starting to peel, any ideas or adhesives i should look into to try to apply myself onto the strip? Name:  int_zps5879dfba.jpg
one more thing, the rubber door trim on the drivers side door wont fit back into place, ive tried several times to try to squeeze it in back where its suppose to be but keeps popping out? do i need a whole new strip?Name:  sea_zpsf94ca666.jpg
thanks in advance!!
Old May 16, 2014 | 11:19 PM
Kaseykasums16's Avatar
Bump. Have the same issues OP. I think the door rubber had to be glued from what I understand.
Old May 16, 2014 | 11:43 PM
mathnerd88's Avatar
As for the wood trim, you would need a new trim piece or you can try gluing it back. Home Depot can help you with the type of glue needed.
As for the door trim, that is easy. You just need to use a screwdriver (wrapped with towel so it won't scratch your door) or plastic trim tool and push it back into place. Make sure the inner rubber line is seated properly or else it will keep popping out again.
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
BlueBelleG35x
Jul 23, 2015 02:10 PM
