2008 g35s dash board problem!!!
Old Jul 2, 2014 | 03:28 AM
Victorg35s's Avatar
Has any of your dash boards Light flicker only on my RPM 6,7 flickers and eventually turns off only in that section help?
Old Jul 3, 2014 | 09:13 AM
infinitidude's Avatar
The instrument cluster will need to be replaced unfortunately.
Starting to see this becoming more common as they get a little age on them. Hope this helps.
Old Jul 3, 2014 | 11:56 AM
Victorg35s's Avatar
Originally Posted by infinitidude
The instrument cluster will need to be replaced unfortunately. Starting to see this becoming more common as they get a little age on them. Hope this helps.
Hopefully. Warranty covers it
Old Jul 3, 2014 | 11:57 AM
Victorg35s's Avatar
Old Jul 3, 2014 | 01:46 PM
DBAguy's Avatar
Mine is also like that. It intermittently goes on and off. I've noticed it more during hot weathers compared to cold.
Old Jul 3, 2014 | 02:38 PM
E-Ticket Ride's Avatar
See my thread:
https://g35driver.com/forums/g35-sed...-flashing.html
Yes, it's covered by your extended warranty (hope you have the extended warranty as the factory warranty is long expired)
Old Jul 3, 2014 | 05:19 PM
Victorg35s's Avatar
Originally Posted by E-Ticket Ride
See my thread: https://g35driver.com/forums/g35-sed...-flashing.html Yes, it's covered by your extended warranty (hope you have the extended warranty as the factory warranty is long expired)
I have the Toyota. Plus care plan
Old Jan 31, 2015 | 04:03 AM
Ozzfest's Avatar
So bummed. My G started doing the same thing. Out of warranty AND extended warranty as well. Anyone have any luck replacing it aftermarket not through the StealerShip?
Old Jan 31, 2015 | 05:39 PM
I honestly don't know if you can consider that to be "worth it" or not. The cluster itself is easily over 1k, then you have to add on the horrendous labor charge (don't forget, the dash has to be removed).
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
crazy_g35s
Jul 20, 2015 02:30 PM
newbdriver01
Jul 15, 2015 06:10 PM
