I have more tire wear on Rear Right than Left ?? ,...Car is a G35S 2007
Tires are Potenza RE760 , Does anybody have any idea why??
Urbanengineer
close
- Join DateJun 2013
- LocationOH-IO
iTrader Positive Feedback100
iTrader Feedback Score(3)
Liked:1,045 Times in 960 Posts
Last time you've had an alignment? Do you weigh over 300 lbs?
Lartytiejdke3
close
- Join DateAug 2011
iTrader Feedback Score(6)
Liked:989 Times in 825 Posts
Lol those aren't even that bad
Alignement was checked and good!,... Tire pressure equal on both tires,..I weigh 165 , so i dont understand why right tire is wearing faster ??
Could it be something about the compound of the tire that is a little different?
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
With the tire on the right, at some point it was over inflated or your alignment mechanic works for Firestone/Goodyear or PepBoys! (doesn't know his job)
Gary
Gary
Doesn't really matter that they're evenly inflated, cuz we don't know what kind of roads you drive on. What's the PSI?Originally Posted by randyc
Alignement was checked and good!,... Tire pressure equal on both tires,..I weigh 165 , so i dont understand why right tire is wearing faster ??Could it be something about the compound of the tire that is a little different?
vqsmile
close
- Join DateOct 2010
- LocationSF bayarea (925)
iTrader Feedback Score(1)
Liked:427 Times in 368 Posts
I have more tire wear on Rear Right than Left ?? ,...Car is a G35S 2007Tires are Potenza RE760 , Does anybody have any idea why??
Quote:
You have the limited slip diff, so it is possible that it is worn out. IIRC, they are a viscous coupled unit and will wear out with time/mileage/abuse. 306hp on an essentially open diff could cause that kind of tire wear. That said, it is possible one of the tires was old and hardened compared to the other one. Originally Posted by randyc
32-33psi
(edited tire pressure comment)
Use a different tire brand that is better. How many miles do you have on them
[QUOTE=vqsmile;6955108]You have the limited slip diff, so it is possible that it is worn out. IIRC, they are a viscous coupled unit and will wear out with time/mileage/abuse. 306hp on an essentially open diff could cause that kind of tire wear. That said, it is possible one of the tires was old and hardened compared to the other one. Also, for the record, that's too little psi to be running in the car, but it's not the cause since it would tend to wear the inner and outer edges on both tires.[/QUOTE
Yes the limited slip diff, ...I though about that?
...Could it be the Right Slips first before the left locks ?
I put my 32-33PSI when tire is Cold ??
vqsmile
close
- Join DateOct 2010
That's what I was getting at; that you could possibly be slipping one tire more than the other.Originally Posted by randyc
...Yes the limited slip diff, ...I though about that?
Sorry about that tire pressure comment, it was my bad. I was thinking of the 19" sport wheel setup which is supposed to be 35psi cold. The correct pressure with your 18" sport wheels is 33 psi cold.
Well Vqsmile,... your guess about the "Worn" Limited Slip Diff seems to be to most probable cause. Originally Posted by vqsmile
That's what I was getting at; that you could possibly be slipping one tire more than the other.Sorry about that tire pressure comment, it was my bad. I was thinking of the 19" sport wheel setup which is supposed to be 35psi cold. The correct pressure with your 18" sport wheels is 33 psi cold.
If this is correct, that means i'm loosing a lot of traction on Hard Accelerations in summer and even more in winter correct??
Do you think most RWD owners here re-build ther LSD when worn out??
Urbanengineer
close
- Join DateJun 2013
- LocationOH-IO
Quote:
It really depends on what their parents can afford Originally Posted by randyc
Well Vqsmile,... your guess about the "Worn" Limited Slip Diff seems to be to most probable cause. If this is correct, that means i'm loosing a lot of traction on Hard Accelerations in summer and even more in winter correct?? Do you think most RWD owners here re-build ther LSD when worn out??
