Oil Catch Can
Old Jan 9, 2015 | 01:47 AM
beto4632's Avatar
Oil Catch Can
Anyone have a catch can in there G.
Stumbled upon a post, and looks beneficial to the engine but could not find info on were to connect the hoses too.
Old Jan 9, 2015 | 06:58 AM
Lartytiejdke3's Avatar
Here's how I did it I think there may be a couple different ways Oil Catch Can-h0wkxoq.jpg
One of the least flattering pics of the bay lol
Sorry dude
Old Jan 9, 2015 | 09:59 AM
HotRodG35's Avatar
Most install oil catch can between return line from PCV mounted on passenger side valve cover to intake.
I run two oil catch cans. One for PCV return and other from driver side valve cover vent to air filter.
If FI its beneficial to drill out PCV for adequate vent under boost. You will need to install another check valve, my choice is the MOROSO Accusump check valves.
Old Jan 9, 2015 | 10:27 AM
bluedevils95's Avatar
Yeah ppl have them on the G but how many of them are 2nd gen
Old Jan 9, 2015 | 10:56 AM
Originally Posted by HotRodG35
Most install oil catch can between return line from PCV mounted on passenger side valve cover to intake. I run two oil catch cans. One for PCV return and other from driver side valve cover vent to air filter. If FI its beneficial to drill out PCV for adequate vent under boost. You will need to install another check valve, my choice is the MOROSO Accusump check valves.
bah you don't know nuffin
Lol
Old Jan 9, 2015 | 12:19 PM
beto4632's Avatar
Yes, I see a lot of people have them on 1st gen g35 but cant find much on 2nd gen g35's.
Old Jan 9, 2015 | 02:10 PM
beto4632's Avatar
Looks like we fallow the HR version correct
Old Jan 9, 2015 | 05:27 PM
vqsmile's Avatar
Unless you're running boost, there is no reason for using a catch can (other than bling ).
Old Jan 9, 2015 | 08:09 PM
saywat?'s Avatar
Sorry dude
I still don't get how having it lay side ways like that doesn't cause the oil to be sucked into the hose going out back into the IM
it collects a good amount of oil in the can. I think that alone is beneficial enough
Old Jan 9, 2015 | 08:15 PM
gary c's Avatar
I'm Back...
I disagree ^ while installing Motordynes 1/2" spacer back in '05 I discovered oil residue in my upper plenum. Remember Dave O editor of Nissan Sport mag? Contacted Dave and he suggested I start with Home Depot's simple catch can, that's what he was running at the time. Spent more $$ on quality line/hose than the can, and it worked! After installing a polished upper plenum months later, there was no sign of oil residue! I currently run a polished C6 Vette catch can, bling maybe but it collects oil residue which I'd rather not have running thru my plenum...Gary
Old Jan 9, 2015 | 10:48 PM
Urbanengineer's Avatar
Your back!
Welcome back.
Good info.
Old Jan 9, 2015 | 10:54 PM
glad you're back
Now bring back the other old school G guys.
Old Jan 10, 2015 | 12:11 AM
Again you are a 2 gen which most of that really don't apply. Your car is fine
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
