v36 sedan Whiteline Bushing fitment
Old Feb 4, 2015 | 08:00 PM
SlimTV's Avatar
Can anyone tell me if the whiteline bushing kit (WEK-003) fits the 2nd gen G sedan. I know it fits the gen 1 G35 sedan and coupe. But I would like to know for certain if they fit on the 2007 and 2008 sedan (awd). Helping a friend get his car tightened up for a lowered suspension and 22" wheels on a 2007 G35x sedan. I used the search, and found the differential kit works on every Infiniti G sedan and coupe from 2003 to now?? Looking to upgrade all the mentioned bushings in the whiteline kit. Priority would be the front lower control arm inner and outer bushings, as well as the compression rod bushings. Thanks.
Old Feb 9, 2015 | 09:41 AM
G force's Avatar
https://g35driver.com/forums/v36-eng...g-install.html
This may be helpful for the rear diff bushing. Be careful with vendors claiming fitment between gens as they sometimes get confused. I suppose by asking on this forum you are, in fact, being careful. I am not confident enough to provide a good answer however I do not believe the V36 has compression rods like v35.
Old Feb 9, 2015 | 03:09 PM
SlimTV's Avatar
What performance aftermarket bushings fit the 07 to 08 awd "X" sedan models? Other than the solid SPL bushing? Are there any known upgrades for the factory front lower control arm bushings?
jsimonk
Dec 22, 2023 03:49 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
MrKrabs
Jul 23, 2015 05:41 AM
LoSt180
Jul 15, 2015 08:31 AM
