Helpppp Code P0171
Old Feb 17, 2015 | 09:08 PM
Isayany's Avatar
Red face Helpppp Code P0171
I have a 2007 Infiniti g35 X , for the last two weeks my car has been hesitating between 1000-2000 RPMS.. Other than that the car drives good. Yesterday my service engine light came on with a code of P0171 .. I want to just replace the MAFS but I'm not sure if that's actually it .. :frown: (My O2 sensors and cat have been recently replaced) I have an extended warranty with Allstate but the last time I used it I paid 800 out of pocket so I'm looking to do it on my own . Thank youuuu
Old Feb 18, 2015 | 01:51 PM
v36skyrine's Avatar
You have most of your answers already... p0171 means that you are running lean... electrically, it can mean MAF sensors or o2 sensors... mechanically it can mean your catalytic converters or as simple and fuel starvation due to weak fuel pump or dirty, plugged fuel filters... what kind of gas do you pump? And what brand?
Old Feb 18, 2015 | 03:09 PM
Isayany's Avatar
I got the car back in August , since it's been I've had it I only put 93 usually from Mobil .. I'm just not sure it's the MAFS just case I've read if it's the MAFS it's usually two codes
Old Feb 18, 2015 | 03:12 PM
v36skyrine's Avatar
Unplug your mafs and start your car... does it get worse? If not, than that may be the issue
Old Feb 18, 2015 | 03:13 PM
Isayany's Avatar
I'm working late today but I will definitely try that tomorrow and update
Old Feb 18, 2015 | 05:53 PM
bluedevils95's Avatar
Mobile gas is not the best gas out there.
Old Feb 18, 2015 | 07:14 PM
v36skyrine's Avatar
Agreed... shell or chevron only for me
Old Feb 18, 2015 | 08:02 PM
^+1 for that. Once in a blue moon I put 76 in when i get too low and just have to stop there
Old Feb 18, 2015 | 08:05 PM
v36skyrine's Avatar
^+1Lol I thought I was the only one that settles with 76 when I know I won't make it to a shell or chevron lol
Old Feb 18, 2015 | 08:06 PM
ScraggleRock's Avatar
This code comes up very frequently on fords and is almost always a dirty MAF sensor.
Old Feb 18, 2015 | 08:08 PM
Mobile, 76, Chevron and Shell are all top tier gas stations. They should all be of very similar quality.
Old Feb 18, 2015 | 10:04 PM
vqsmile's Avatar
Yep, the ol' F-250 pops one up every once in a while, but a quick squirt of CRC maf cleaner and she's good to go.
Old Feb 18, 2015 | 11:24 PM
Mobile doesn't put enogh detergent in there gasoline. That's probable why everything is all fouled up and your throwing codes
Old Feb 18, 2015 | 11:37 PM
But they have to to be considered top tier. Top tier is a 3rd party designation.
Old Feb 18, 2015 | 11:42 PM
^^^^^^^^^^ this is very useful. I even post a thread on this as well
http://youtu.be/ystuUJWae0Y
Going to have to copy and paste it. Mobile app is not the perfect thing unless I haven't figured it out yet
