2007 G35x Sedan (NO NAV) - Backup Camera
Old Oct 18, 2015 | 11:07 PM
leo38cheng's Avatar
Hi Forum Members,
Looking for some answers on the backup camera for the 07 G35x Sedan.
I want to go with the OEM look -- but from reading the old thread, I still can not a definite answer on my questions:
--- With the OEM look --- I've heard that the airbag light will start blinking after the install. Is that true? Is that an easy fix?
--- What parts are needed with the OEM look? Any backup cameras you guys can recommend?
--- Other than the OEM look, are there any other backup camera alternatives for the G35x Sedan? Is so, do you have picks or recommendations? Was the install hard to do?
Thanks!
Old Oct 19, 2015 | 09:20 AM
RemmyZero's Avatar
There are a bunch of threads on here for backup cameras, some OEM, some "non". I don't recall hearing anything about the airbag light being affected. It really shouldn't be. Head over to the tech area and search in the "video/electronics" section. You'll find everything you need in there. Installs are fairly easy but if you want to go for the OEM look then the cost goes up a little and it gets slightly more difficult but if you follow the write-ups it's nothing you can't do.
Old Oct 19, 2015 | 01:41 PM
navtool.com's Avatar
Originally Posted by leo38cheng
Hi Forum Members,
Thanks!
hi
all you need is this interface
http://www.navtool.com/infiniti-g_07-09wo.aspx
we also offer one with built in smartphone mirroring via HDMI. You can use to display navigation and other apps to display on factory screen
Thank You
Speck102
Mar 26, 2018 11:48 AM
Jiggerjuice
Aug 17, 2015 08:41 AM
dimentio1
Aug 16, 2015 11:47 AM
smartin0924
Aug 13, 2015 07:29 PM
TL2G35x
Aug 12, 2015 10:30 AM
