help with tail as turn module wiring
Old Oct 31, 2015 | 01:37 PM
youngdip631's Avatar
Purchased a tail as turn module for my 07 g35x sedan and going to do away with the middle signal bulb, does anyone know which 2 wires im going to have to crimp into the 2 input wires on the module? I seen diode dynamics video but it was for a g37 coupe and im cannot see the actual wire colors up close/i dont know if the wiring colors are the same.
Old Nov 2, 2015 | 01:53 AM
takeapieandrun's Avatar
The green wire w/ yellow stripe goes to the LED ring, and the plain green wire goes to the turn signal. Cut & crimp both of those into the module, and then crimp the output back onto the green wire w/yellow stripe. Dont forget your resistor to fix hyperblink. That can go across the solid green to solid black turn signal wires. Check out this thread:
http://www.myg37.com/forums/g37-seda...ynamics-3.html
Old Nov 2, 2015 | 08:22 AM
PGg35s's Avatar
Do you guys have the plug and play kit yet?
Old Nov 2, 2015 | 08:24 AM
PGg35s's Avatar
Disregard that last post.. I am on garage talk and forgot to switch to myg37. Thought this was a diode dynamics thread.
Marlin84
Apr 1, 2020 12:52 PM
Xfactor
17 Inch
May 13, 2017 02:35 PM
AJC128
Nov 1, 2015 11:55 AM
INVADER_6MT
Oct 21, 2015 03:44 PM
CouperDouper
Accessories
Oct 3, 2015 02:38 PM
