Need help with a gasket size.
Old Jul 27, 2016 | 12:00 PM
El_Donks's Avatar
I was recently rear-ended and the Y-Pipe loosened up from the Mid-Pipe. After tightening it up, the juncture is still leaking. I attempted to get the gasket dimensions from the manufacturer (Megan Racing) but they have not provided a response. Would anyone here happen to know what size gasket I need? I know that the flange is 3" but need to know the hole diameter.
Old Jul 27, 2016 | 03:24 PM
blnewt's Avatar
This should be the part you need
https://www.amazon.com/Berk-350Z-Y-P.../dp/B008HRX8JI
Also you might be able to just get by w/ Permatex Red high temp RTV sealant if it's a small leak. Apply it to both sides of the gasket, just lightly snug down the bolts, wait an hour then torque to spec.
Old Jul 27, 2016 | 06:40 PM
El_Donks's Avatar
Awesome, I was considering that one the other day but wanted to be sure (since my Y-Pipe is from another manufacturer). Just as a safeguard, I went ahead and ordered a 2.75" and 2.5" One of those will definitely work. Thanks for your insight!
Marcos360
Sep 25, 2016 01:41 PM
Neowind
Jul 27, 2016 01:31 AM
Edgar0529
Jul 25, 2016 12:12 AM
slcg35x
V36 Brakes, Suspension, Wheels & Tires
Jul 21, 2016 04:20 PM
Rawrster
Intake & Exhaust
Jul 15, 2016 01:12 PM
