Airbaglight stays on
Old Jan 15, 2017 | 03:12 PM
Juan.sco's Avatar
Hi all
I have 07g35 and i removed the passenger seat for cleaning. After putting it back in the airbag light went on and it stays on. I've double checked the wires but the problem remains. Even tried the diagnostics method switching on and off but no use. Any ideas what the problem might be?
Old Jan 16, 2017 | 07:34 PM
Ketchup83se01's Avatar
Need to plug it into obd2 scan tool and have it reset. Next time you do that disconnect the battery first, theres an airbag in the seat. Someone correct me if im wrong
Old Jan 16, 2017 | 07:44 PM
Juan.sco's Avatar
Ok thanks.
ill give that a try and keep you posted
Old Jan 17, 2017 | 11:58 PM
Urbanengineer's Avatar
This is gonna sound silly but try this - turn the car from off to on (but not starting) to off 5 times, with 2 seconds of pauses between off - on - off. Should temporarily reset the light, and if there is greater issues the light will come back.
