g35s quick release steering wheel
Old Jan 29, 2017 | 02:20 AM
Johnny Vazquez's Avatar
What's up their ppl I have a quick question I am trying to put a quick release steering wheel on my 07 g35s ...and I am kinda confused if I put a quick releases steering wheel will I b subtracting my shift paddles or will I still b able to leave them on ...plz help thank u and appreciate it
Old Jan 30, 2017 | 11:49 AM
Urbanengineer's Avatar
Depends if it is compatible. Contact the manufacturer of your shift paddle.
Old Feb 6, 2017 | 12:35 PM
Mustang5L5's Avatar
The paddles are attached to the column, so in theory they can stay and should work.
BUT, the real issue is clearance once you put the quick release on with an aftermarket steering wheel. The wheel might sit too close and hit the paddles, so you may need to remove them.
No way to tell until you mount it all up.
I also think it's not going to be a very clean install as there's a lot to cover up here with the OEM wheel removed.
