So after countless amounts of searching for a solution to this problem I have on my G, I have only been seeing the same results for window problems and most of the time it was resetting the limiters. My problem involves not being able to roll up/down my driver and the passenger side windows from my driver side. But, it will eventually work if i just hold down the button. FYI, the rear windows work perfectly. Also, the auto-down feature for my driver side window does not work but it works for the passenger side (through driver's switch). My judgement call is the master switch needing to be replaced or possibly bad connections with the wires on the switch. I do not believe the motors and regulators need to be replaced since the windows are rolling up and down. Any suggestions?
