Temperature gauge light
Old Apr 14, 2017 | 07:58 AM
mahendra26's Avatar
The temperature gauge light on my 2008 G35 flickers and goes off. Stays off and then, at random, does the same thing again. The gauge appears to be functioning properly. Is this a bulb that I can change? or is the bulb inbuilt in the instrument cluster and the whole cluster needs to be changed? If it is a bulb I can change, where do I get a spare bulb?
Also, does anyone have detailed instructions on how to remove the instrument cluster?
Thanks.
:confu sed2confused2confused2:
Old Apr 14, 2017 | 04:27 PM
telcoman's Avatar
Veteran: Army
Thanks.
Possible bad ground or poor connection in the wiring harness?
Check out the FSM
http://www.nicoclub.com/service-manu...Sedan/2008/MWI
Telcoman
