Torque spec for front suspension
Old Apr 29, 2017 | 11:05 PM
EricF's Avatar
I've read the FSM, but after stripping a the threads out of nut, I'm wondering if there's a typo. The bolt in question is the lower front shock mount/sway bar end link. The FSM says 120 ft-lbs, but the threads were gone before I hit that. Any ideas?
Thanks.
Old Apr 29, 2017 | 11:47 PM
ScraggleRock's Avatar
Impact gun tight.
Old Apr 30, 2017 | 10:47 AM
victor0206's Avatar
So are you trying to tighten the bottom half of the end link or the bottom half of the shock?
Old Apr 30, 2017 | 11:39 AM
EricF's Avatar
Impact gun tight is a bit vague. Mine supposedly goes to ~150 ft-lbs.
victor0206- I'm trying to tighten the big 19mm nut in the middle:
As it is now, the threads pulled out of the OE nut and I'm waiting on a new endlink from O'Reilly.
Old Apr 30, 2017 | 05:32 PM
Txg35guy's Avatar
I literally just finished replaced one of my front shocks (next one done next weekend).
And that black bracket you have arrows to I could not for the life of me get more than 3 bolts back in it!
So the 3 on the right are in, the far left one is slightly offset, making putting the nut back in impossible.
I've raised and lowed the suspension with a jack with no luck to repositioning the hole.
any ideas?
Old Apr 30, 2017 | 06:12 PM
EricF's Avatar
I'm guessing either the nut was defective or I minutely boogered the threads on the bolt enough to cause damage, but it looked OK. Either way, a new Moog end link was the solution. The drivers side was totally fine with the OE link.
As far as getting everything lined up is concerned, I found keeping everything slightly loose helped dramatically (including the three nuts on the upper mount). The black bracket on my car moved a few mm when loose, and went in without much issue. I also dropped the sway bar bushing mounts, which really freed up the main lower bolt. Good luck!
