Front o2 sensor
Old May 30, 2017 | 12:16 AM
Jdmay35x's Avatar
Front o2 sensor
Got the code for passenger side o2 before cat. In the process of removing sensor the threads were stripped. Right now I have it plugged as I figure out best course of action. Car has 212k, so with that in mind I really just want to jb weld it in there or get the fouler plug and do it that way....flame on...
Thoughts
Old May 30, 2017 | 12:46 PM
LoSt180's Avatar
Threads to put the sensor in the header are stripped? The front O2 sensor is important for proper operation of your car, the rear sensors are just for the cats and can use the anti-fouler spacers.
You should be able to buy a tap set for that O2 sensor to clean up the threads so you can install the sensor properly.
