2007 g35x problemmm need help
Hi im new on this i buy a 2007 infiniti g35x and he run good no check lights on he run good but when i stop and i hit the gas to go feel like miss power for a second and keep going normal if i hit the gas slowly no do it any suggestions what can be the someone can help me out thanks
First check and replace the spark plugs with OEM plugs if needed. If they're NOT OEM plugs replace them regardless of condition. Next perform these reset procedures, you will need a timer with seconds displayed, the counts need to be very exact. Perform all 4 resets in the order they are listed, you may have to try a couple times to get them to work but you don't need to start from the very beginning if you screw one up.
Perform these resets only after the motor is at operating temperature or the idle air calibration will be off.
http://www.nicoclub.com/archives/g35...procedure.html
