Engine Splash Shield
Old Dec 16, 2018 | 11:33 AM
Joenavy85's Avatar
G35x Base
So I bought a replacement splash shield for my 08 X model and I'm curious as to why the flap that it has doesn't have a way to stay fully closed. It's got 4 screws holding it on the back side and it just dangles down on the front side. Is there a real reason to have it do that? Or can I just zip-tie it closed?
Old Dec 16, 2018 | 12:40 PM
treacherous's Avatar
20 Year Member
G35x
It should have a 10mm bolt that holds it on the front.
Old Dec 16, 2018 | 01:27 PM
FreshLikeAG's Avatar
Should screw into the front bumper. Maybe you have an aftermarket bumper?
Old Dec 16, 2018 | 01:30 PM
Joenavy85's Avatar
G35x Base
Clearly I'm bad at explaining and need pictures. This flap.
Old Dec 16, 2018 | 01:54 PM
Looks like you need the u nut clips to go over the two holes and the m6 1x25mm bolts. The clips have threads that the bolt screws into
Old Dec 16, 2018 | 02:01 PM
20 Year Member
G35x
__+1
Old Dec 16, 2018 | 02:03 PM
Joenavy85's Avatar
G35x Base
Ok, that's easy enough, thanks.
Old Dec 17, 2018 | 01:27 PM
telcoman's Avatar
Veteran: Army
My 06 did not have that
Telcoman
Old Dec 21, 2018 | 01:30 AM
Silversleeper86's Avatar
G35 Sport Sedan 5AT
I doubt that part used bolts with nut clips. Look at the holes at the corners on the splash shield. There's no way the nut clips will fit without modification. I would just use the plastic retainers
edit: Upon more looky looky at the photo...I don't know which is up or down. If the nut clips go on the flap then no problem. Just seems unlikely they'd use 3 bolts for a small flap like that.
Old Dec 21, 2018 | 03:33 AM
909's Avatar
909
Your mom's boyfriend
Push in retainers.
If there are none handy, I'd zip tie it.
Old Dec 21, 2018 | 10:11 AM
Hall Stevenson's Avatar
It uses nut clips. The nut clips are somewhat spring-loaded so they will 'clamp' on the plastic part of the non-flap portion. Two of mine have fallen off over time and only one remains and it's more than enough to keep the flap closed. Or maybe the outside ones were push-pin type and only the center one used a fastener and nut-clip.
Old Dec 22, 2018 | 03:48 PM
20 Year Member
G35x
Nice having the trap door... it has always made oil filter changes a lot easier.
Old Dec 22, 2018 | 04:07 PM
Joenavy85's Avatar
G35x Base
I went ahead and got 3 appropriately sized jack nuts and will be installing them prior to putting the splash shield on next weekend.
Old Dec 23, 2018 | 11:23 AM
Mr.GEE's Avatar
20 Year Member
Coat the threads of both the jack nut and the bolt prior to installation. If any rust forms on either one. the jack nut will spin and you will never get it off. Happened to a friend and he had to remove the entire shield so he could hold the nut with pliers to take off the bolt.
azt108
Oct 7, 2017 06:43 PM
junebug35
Archived Sales
Dec 30, 2009 08:31 PM
