Fuel door help
Old Jun 11, 2021 | 02:40 PM
sternfan619's Avatar
G35x Sedan
Fuel door help
Ok I have searched how and low for an answer but can’t find one. My gas door only opens if you push it on the right and it can be quite hard sometimes. Isn’t there supposed to be like a spring actuator that pops it open when you press it? It has the black spring on it but I don’t think it does much
Old Jun 11, 2021 | 04:33 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yes there is a lock actuator that extends a little plunger out to lock the gas door.
Open the fuel fill door, look at the side where the plunger is, hit your lock button on your key fob, now hit your unlock button on the key fob, does the plunger extend/retract normally? If not then unlock the car again and see if you can push the plunger back in a little. I suspect the plunger arm is broken and no longer attached to the actuator.
Pretty easy to replace the entire assembly if it's broken, you can access it through the trunk.
If the plunger is broken you can probably just pull it out easily with your fingers, the fuel door will no longer lock but at least you won't have to jimmy it every time you want to open the thing.
Old Jun 11, 2021 | 04:57 PM
909's Avatar
909
Your mom's boyfriend
The gas door does not open automatically.
Your door is misaligned.
Loosen both bolts.
Adjust.
Re-tighten.
Old Jun 11, 2021 | 07:57 PM
G35x Sedan
The lock pin is there and it does work to lock and unlock but the struggle is when it’s unlocked you kinda have to use a credit card to pry it open. I thought there would be a spring that opens and closes when pressed.
Old Jun 11, 2021 | 09:13 PM
cleric670's Avatar
BANNED!!!
On the V35 platform you have to push the gas flap in until it sort of clicks then when you release it opens the door for you automatically about 1/4 of the way. I don't know how the gas flap on the V36 platform functions but I assumed it worked in the same fashion.
Mr.GEE's Avatar
20 Year Member
Just push in on the edge of the hinge side. The door will open enough to pull it open with your finger from the latch side. On my coupe and the wife's Q50, if you push on the latch side, the door pops out enough to pull it open the rest of the way. The G35X never worked that way. We always had to push on the hinge side first.
Old Jun 11, 2021 | 09:37 PM
G35x Sedan
I have the V36 platform so I guess I’m stuck with the current door I have. I have no clue why they would remove the spring switch from the V35 to the V36
Old Jun 12, 2021 | 06:35 PM
treacherous's Avatar
20 Year Member
G35x
Normal.. guess I am used to it after 14 years :-)
StevenK
Feb 23, 2016 01:40 PM
01SVT
Jun 29, 2013 10:19 PM
BJD275
Jun 24, 2009 05:05 PM
infg35coupe
Apr 18, 2009 01:44 PM
nthnbutaGthang
Nov 2, 2003 11:40 PM
