G35 2008 AWD(Identify)
Old Dec 15, 2021 | 05:02 PM
Runecraft's Avatar
2008 G35 AWD X
So i was making a wide you turn when my axle poped out of socket i took a looked and it was clean pop out, the rubber boot went flying etc.
In the process of moving the car (AWD) up the flat-bed tow i think something got stuck with the axle and it bent the whole thing, i'm trying figure out what it is it's leaking oil.
The top picture is after, the bottom is before right after it poped out. Somehow in the process of moving the car it got tangled with this line ,power steering is hard seems related anyone know?
Old Feb 3, 2022 | 12:12 PM
2k8Xs's Avatar
Silver Xs, exhaust, 09 sport brakes.
Likely it is just axle grease that has thinned out. Since the axles are flange mounted, you're less likely to have a bad cv shaft seal but I suppose it's still possible. The color of said "oil" should tell you what you need to know.
Old Feb 16, 2022 | 11:57 PM
Runecraft's Avatar
2008 G35 AWD X
Ended up being high preassure power steering line wrapped around the axle, the problems continued and i went thru 5 axles ,had to change the lower control arm and motor mounts , lost all confidence in the car and now i am afraid the axle will popout again while on high speed drive, i am scared to touch the car now after this whole ordeal, i replaced motormounts/power steering lines,lower arms and went thru 5-6 axles.
HeadTurner 555
May 16, 2022 06:20 PM
speedjunkie_G35
Jul 20, 2019 10:54 AM
G2FAST
SOCAL Meetings & Events
24
Aug 22, 2008 08:48 AM
