G37 Coupe V36 2008+ Discussion about the G37 Coupe
TT for the coupe?
Old Feb 1, 2007 | 03:47 PM
finagle69's Avatar
Question
Originally Posted by asianautica
I highly doubt the VQ37HR will make 330HP much less 345HP. The current VQ35HR makes 306HP which is 87HP/L. if the VQ37HP make 330HP, that'd put it @ 89HP/L and 345HP would put it @ 93HP/L. We all know as the engine gets larger, it's harder to squeeze out more HP/L in NA form without additional technologies such as FI or VVL. So unless the VQ37 is a VQ37VE, I highly doubt it can make that #.
unless i'm missing something, 350in^3 equates to 5.735472 Liters, not 3.5172
what is your calculation based on?
Old Feb 1, 2007 | 03:51 PM
asianautica's Avatar
306HP/3.5L = 87.4HP/L
330HP/3.7L = 89.1HP/L
345HP/3.7L = 93.2HP/L
IIRC, the only Nissan engines to date that get 90+HP/L are either VVL or Turbo engines.
Old Feb 1, 2007 | 05:08 PM
finagle69's Avatar
oops. i used cubic inches. derp.
Old Feb 1, 2007 | 06:37 PM
jdm rice's Avatar
I agree, but then again, who knows if the VQ37 will be a stroked version of the current HR or be something totally different...only time will tell
Old Feb 1, 2007 | 07:17 PM
I agree, that's why I say it would only reach those number if it's different than just a stroked or bored VQ35HR. I.E. either use FI or VVL or variable compression tech that they're researching.
Old Feb 1, 2007 | 09:18 PM
RBull's Avatar
Rated M
Good post. As you probably know BMW gets 104/litre with their E46 and E85/6 engine NA and other like Honda S2000 get some impressive numbers. It will be interesting to see how much more may be punched out with the 3.7. It's supposed to be a "limited production" engine.
370 = 100HP/L
Old Feb 1, 2007 | 09:26 PM
370 = 100HP/L
Both the M3 and the S2k have variable LIFT which is similar to VVL. Nissan had VVL implemented in their SR engine. The SR16VE maked 195HP IIRC. Which would put it @ 121HP/L. They also had SR20VET which make 280HP. So if you add VVL and a turbo in the mix, you get 140HP/L. Nissan knows how to make high HP/L engine, no doubt. Rumor has it that the VQ37HR from the GT-R is tuned by Cosworth and it supposed to rev well above 8k RPM and have VVL. So if that's true then, the VQ37HR will have no problem hitting 100HP/L w/ proper tuning.
Old Feb 2, 2007 | 02:31 AM
jackygor's Avatar
All these rumors about the new engine is giving me a boner.
Old Feb 2, 2007 | 12:10 PM
RBull's Avatar
Rated M
Good explanation and sound logic. One of the car mags wrote that Cosworth was working with Nissan on engine developement/tuning. I would be disappointed if we did not see something closer to 100hp/l and use of direct injection.
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
Th611
Oct 27, 2015 03:48 PM
Kal Hamm
Jul 24, 2015 08:55 AM
