G37 Coupe V36 2008+ Discussion about the G37 Coupe
G37 Tech Specs, Features & Options
Old Apr 5, 2007 | 02:05 PM
  #91
frshgcoupe's Avatar
sounds like someone needs a change of pants!
Old Apr 6, 2007 | 11:06 PM
  #92
dennisjai's Avatar
asdsddasdas
Old Apr 7, 2007 | 08:18 AM
  #93
SPEEED's Avatar
Bad Toro
Great post Shane. Thanks.
Old Apr 24, 2007 | 04:12 PM
  #94
Waz's Avatar
Waz
Sun/Moon Roof
I thought a moonroof only tilts, but a sunroof can slide open (or tilt).
Old Apr 27, 2007 | 01:30 PM
  #95
muscarel's Avatar
In some of the previous literature, they mentioned a more refined 6-speed transmission. I initially was excited as that seems to be the only lasting sticky point with the G (refinement).
The final drive changed to 3.69, which was different than the 07 Z and 07 G coupe. That gave me some confidence that the tranny would finally change - but I just noticed that the 07 sedan has the same final drive ratio. DOes this mean that the "more refined" 6-speed is actually just an improvement over the old coupe, but not necessarily "new" as it is in the sedan already?
Old Apr 27, 2007 | 01:35 PM
  #96
RBull's Avatar
Rated M
Good question. The revised rear drive ratio in both suggests there is a chance another part of the drivetrain (trans) will also be the same.
Old Apr 30, 2007 | 12:02 PM
  #97
GT-Ron's Avatar
The literature also uses "new" or "refined" in conjuction with "lightweight" to describe the 6MT, which gives me hope of more significant improvement over the current 6MT. Doesn't help much, but it does appear that there were some significant revisions. I never remember the current 6MT being described as "lightweight"... ...although it's not exactly robust either.
I can't wait for good reviews of the production-model 6MT... ...or a test-drive of my own to determine the difference.
Old Apr 30, 2007 | 05:03 PM
  #98
muscarel's Avatar
The more I think of it, the more I believe it's the same unit from the '07 sedan. DOesn't seem to make sense to change the transmission in 07 just to change it again for the new coupe. Especially now that I see the gear ratios changed to match that of the sedan. I think alot of items are probably a carryover from the sedan but are considered "new" or "revised" because they are comparing it to the previous coupe. Not necessarily new for the G line.
Old Apr 30, 2007 | 06:16 PM
  #99
finagle69's Avatar
This is exaclty how i read it. much the same as "36% stiffer suspension"; stiffer than that of the existing coupe, not the new sedan.
of course your argument of "DOesn't seem to make sense to change the transmission in 07 just to change it again for the new coupe" can be disproved by looking at the engine change
Old Jul 1, 2007 | 06:11 PM
  #100
mal_TX's Avatar
Originally Posted by FAST1
I defined low end by being under 5K RPM. If you spend all your time driving at redline, then you're in that .00000001% that I alluded to. Most car owners don't like to have to drive at 7K RPM to experience a car's power, especially when the price of a gallon of gas is approaching $3 again. If you aren't impressed by the 335, then you are in a tiny minority again.
You burn plenty of fuel accelerating hard in a very torquey car at low RPMs.. nearly the same as revving high. So yeah, let's forget about the "gas prices" thing.. I could understand if people don't want to rev high because it is loud or whatever, but it doesn't have THAT much to do with the fuel consumption.
Winding the motor up quickly (at low or high revs) is what uses the fuel. The high revs just use a little more due to increased friction, but not nearly as much as you imply.
Old Jul 1, 2007 | 06:12 PM
  #101
mal_TX's Avatar
The increase is stiffness refers to the chassis -- the car itself is 36%-40% stiffer depending on which article you are reading. Suspension may or may not be stiffer.
When I had an 07 G sedan as a loaner, the increased chassis stiffness was an OBVIOUS improvement in the car's behavior.
Old Jul 12, 2007 | 05:35 PM
  #102
tmac911's Avatar
Does any1 know what the interior would look like without NAV?
Old Jul 12, 2007 | 05:39 PM
  #103
Yimbie's Avatar
Yin-Yang and Life
Same. The screen is still there. The nav buttons are just changed.
Old Jul 19, 2011 | 07:21 AM
  #104
indiandrives1's Avatar
Great to know this guys.......
Old May 24, 2020 | 12:42 AM
  #105
juliofbz47's Avatar
2008 infiniti g35
Vdc
I heard turning off the VDC button still won’t allow for drifting/donuts.
Is this true?
John6mt
Apr 1, 2009 06:01 AM
Kidcane
Aug 6, 2007 03:20 PM
Queens350z
NorthEast
33
Aug 6, 2007 01:38 PM
