Driver side door doesnt open via keyless entry
I have a 2010 G35 and the dirver side door does not open unless I put the key on the top of the car. The passenger door works fine, and the both the buttons on the key and the button on the door work fine once the key is basically on the top of the car. I already changed the battery in the keys and disconnected the battery for 30 minutes and still nothing, any advice?
Not very many components to the system, fob has a transmitter, buttons, battery, those all appear to be functioning.
Car has an antenna, BCM (computer), wiring, door lock mechanism. Sounds like the only component with problems is the locking mechanism.
Every other function of the fob works at normal range correct? And the door unlock mechamism on the passenger door functions normally yes?
I'd suspect either the door striker motor or the wiring, unplug it and get a meter on it, have someone else stand back a ways and trigger the unlock while you check for signal. If it's getting the correct signal then the door lock striker motor is shot.
You can buy a second fob for $20 at an auto parts store (generic fob but the spare I have looks darned near identical to the stock one) program it yourself and see if just the fob is trashed, then you will have a spare fob to go with your future spare key!
