how well can g35c take curves at high speed?
Originally Posted by Deang35c6
It was probably your all season tires. Are they new? An all season will never perform as well as a full time summer or winter tire. When you're running Michelins in the front and all seasons in the rear, the rears will probably break loose alot sooner than the front while inducing the slip. Personally, I will never use all seasons again.
On mine, I had Michelin Pilot Sport A/S on all 4 corners, and took some high speed corners just fine....
When my rears wore out, I replaced them with Bridgestone Potenza RE960AS, in the same size as I had before (275/40-18), but left the Pilot Sport A/S in the front, becuase they still had a little more than 50% tread left....
Took at 60mph curve, (that I normally take at 80+), and the VDC kicked in and actually caused the back end to whip out a little.
Replaced the front Michelin Pilot Sport A/S, with a Bridgestone Potenza RE960AS, and my problem went away, and was able to take those highspeed curves again....
VDC was not kicking in because of traction differences, because both tires should have about the same traction, plus I got the VDC to kick in at 35mph, so I doubt I was having traction issues. It was most likely because the Potenzas were 1/10" bigger than the Pilot Sport, which makes the ECU think the tire is spinning faster than it is, so in combination with the Pilot Sport A/S up front, (which is already 2% different size from stock), the slightly smaller Pilot Sport A/S up front (compared to what a same sized potenza would be), was making the VDC think I was losing traction in a turn when I wasn't.
Originally Posted by partyman66
Anytime I've driven that TSX or riden in it, the system will kick in if you have wheelspin, but it doesn't kill all the power.. it just seems to limit power.
The VSA in my wife's TL seems just as intrusive as my G.
Originally Posted by Nikos35
WOW! so vdc applies brakes? I guess I need to do a search!
vdc applies the breaks...thats why people turn it off if they drag race...it turns on the breaks to which ever wheel is loosing grip etc...
I have tried to push it but seems not to do what I want.... like pitching it into the corner. I try and it just grabs..... I gues I'm to n00b for this stuff, but I have drifted vettes, camaro, Izuzu Impulse (yes its possible) but the 35 grabs and makes me smile like I just lost my virginity!
My stock 2006 G35 Coupe 6MT handles very well at high speed cornering. Ofcourse, I don't take 80 MPH corners but I've had my share of similar experiences. I was surpriced to see how well balanced the G35 is (with VDC off ofcourse, its too intrusive).
But keep it safe & smart!
michelin pilot sports are great. dont get the pilot sport AS. they dont stick in the corner as well as the regular pilot sport. but the pilot sport AS lasts twice as long as the regular pilot sport. i have been in the tire industry for 15 years, and you always have to give something to get something. so you need to decide if you want the best handling or some longevity from your tires
One quick question(don't mean to jack your thread, hey, maybe you will benifit). Would this help a great deal: https://g35driver.com/forums/suspension-vendor/137943-gt-spec-chassis-reinforcement-intro-pricing.html
-AGThing1227
-AGThing1227
when i was all stock i used to drive at this one hi-way with a speed limit of 40 at turns i would take that turn at 70 once i did my sways, shocks, struts, springs, gtspect bars, strut bat and 245 front and 285 back i take that same turn at 90 and the rear slides out just a bit so you can say the car handles very good
Terry_G35
Sep 10, 2015 08:17 PM
