Question about wired smell come out when A/C stated
Old Jun 19, 2008 | 11:52 PM
alxwang's Avatar
I just found out this problem in my 03 G35 sedan.
The outside temperature is around 25 c and when I start the car and a/c some wire smell come out from vent. After running for 2-3 minutes the smell just gone.
Does anyone know why and what I should do? Send the car to dealer to do a a/c cleaning service will help?
Thanks
Old Jun 20, 2008 | 12:08 AM
ndlive's Avatar
it's the mold in your air filter... from now, try turning the ac off a few minutes before you turn the car off, so the moisture dries in the vents/filter.
as for now, you can try the mold-remover things that you spray into the vents, or just get your air filter replaced
Old Jun 21, 2008 | 12:35 PM
RBull's Avatar
Rated M
^+1
It's common in a lot of cars.
Old Jun 23, 2008 | 08:47 PM
tdm racer's Avatar
Yup, it's normal, occurs when first starting vehicle and a/c shoots a quick blast of stale air in your face... boo
I've found that running the a/c off or on heater just before shutting down seems to help, as is switching to fresh air rather than recirculated a/c, I've also seen some people use ozone treatment in the a/c system which seems to work, ( though the ozone odor isn't exactly roses either )
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Rehman2009
Jul 27, 2015 03:23 AM
