Door locking issues
Old Aug 3, 2008 | 11:31 AM
Mannyz33's Avatar
Door locking issues
I having issues locking and unlocking the driverside door.
Key fob won't work or locking it with the lock button in the car, I have to manually lock and unlock the car.
I ran across one thread about this after searching that identified the problem as being the door lock actuator which is essentially the motor that locks and unlocks your doors but I could not find the suposed thread on how to fix it.
Can anyone help please
Old Aug 8, 2008 | 12:42 PM
cthrulies's Avatar
diverside door lock issue
Same Problem here. The service manual recommeded lubricating the lock of course. I'll try it and let you know. If tha doesn't work, I'll disassemble the door to take a closer look.
Old Aug 8, 2008 | 04:45 PM
Mannyz33's Avatar
What little info I was able to find myself, looks like it's the Door Lock Actuator. Dealership wanted 255. here in Orlando, here is a site where I founded for 140.
http://www.trademotion.com/partlocat...12&catalogid=2
Old Aug 8, 2008 | 05:55 PM
Manual G's Avatar
Same problem here. I should have some time to check it out on Sunday. If any of you guys figure anything out please let me know.
Old Aug 8, 2008 | 05:57 PM
Dakkerz's Avatar
Since you're in FL you should check this out, they might be able to get you a good deal on one.
https://g35driver.com/forums/florida...blic-sale.html
Old Aug 8, 2008 | 06:02 PM
Mannyz33's Avatar
Thanks! , I've been there with my crew ozoc when I had my 350Z
Old Aug 8, 2008 | 06:03 PM
Mannyz33's Avatar
I ran into a post that some posted they had a lose wire and once reattached all was good. I have not had the time to do that myself
Old Aug 10, 2008 | 04:06 PM
Mannyz33's Avatar
Here is where you can order a replacement at Autozone
http://www.autozone.com/R,690513/veh...ductDetail.htm
And thread on someones after market door locking fix
https://g35driver.com/forums/body-in...uator-fix.html
Door panel and components removal thread
https://g35driver.com/forums/body-in...l-removal.html
I think I'm going to order the part then get in there and see what's the problem that way once apart I can either fix a problem with the actuator or replace it.
Old Aug 11, 2008 | 10:17 AM
Manual G's Avatar
Thanks Manny those are good links.
Old Aug 11, 2008 | 02:16 PM
Mannyz33's Avatar
No problem, I ordered the one from AutoZones's site
mike730
Jan 12, 2018 04:25 PM
xluke
Jul 30, 2016 01:48 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
