Torque Wrench Maintenance?
Old Jan 27, 2009 | 07:00 PM
DrTomSlick's Avatar
Thumbs up Torque Wrench Maintenance?
Just wondering if any1 knows how to clean and maintain a torque wrench. I understand that it should be handled with the utmost care because any kind of abuse will result in the calibration being off. Also when storing the torque wrench the setting should be at the lowest possible level. TIA!!
Old Jan 29, 2009 | 06:20 PM
wingsprint410's Avatar
Not much other than keeping it clean and do not dropping it.
If you use your torque wrench on a regular basis: After 5,000 cycles or one year of use, whichever comes first, have it inspected and recalibrated by the manufacturer or reputable calibration service.
Old Jan 29, 2009 | 07:22 PM
DHCrocks's Avatar
never use it to break loose or remove fasteners.
oil/lube the head like any other ratchet.
Old Jan 29, 2009 | 08:50 PM
DrTomSlick's Avatar
Understood but wat kind of oil do I use to clean the rachet head? Is it ok to take the C-ring out and clean the internals during this process?
Old Jan 29, 2009 | 10:19 PM
DHCrocks's Avatar
only take apart the ratchet head. Do not remove the cap from the end where you set the torque. I usually use brake cleaner to remove all oil/grease. Then depending on the ratchet type lube it up. if it's a low tooth count like 30-36 teeth then use a grease, I use a grease called corrosion block but you can use any type of grease, a moly grease would be ok. if it's a high tooth count like 76-80 teeth I use motor oil. The high tooth gears do not have enough clearance for a grease and will tend to get stuck, so a oil is used.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
DRG35R
Sep 16, 2015 05:33 AM
