FRUITOPIA BOTTLE CAP sized OIL LEAK
Old Apr 27, 2009 | 04:51 PM
t7n7's Avatar
Exclamation FRUITOPIA BOTTLE CAP sized OIL LEAK
K.. i know the title is a lil off but it was the first thing that came into my head when i saw the size of the leak.
I parked my car and didn't really notice the oil leaks right away. Apparently, when i park my car for about 5-8 hours, there is no leak but after leaving it OVERNIGHT, there is about a 1.5" diameter oil patch near the front (parallel to the front wheels.)
Any type of OIL leak just makes me go crazy as I had a bad experience with them from 2 cars ago (2001 toyota camry). After literally 7 trips to the dealership, washing etc., they finally found the problem to be a bad oil filter. !!!!!
Now i'm not 100% sure if this oil leak started before or after my recent oil change (about 2 weeks ago).
I'm afraid the leak has something to do with that engine value thing you guys talked about in the other threads. does that cause a very SLOW oil leak? since it doesn't seem to leave a patch of oil when i leave the car parked for 5-8 hours. only overnight (around 11-12 hours)
I hope its just the oil filter on this car as well... does anyone have any experience with oil leaks? can it be as bad as a new engine required?
Old Apr 27, 2009 | 07:03 PM
jibberjabbers's Avatar
When oil leaks onto the pavements, it's usually caused by bad oil plug washer or bad oil filter seal.
Old Apr 27, 2009 | 07:11 PM
t7n7's Avatar
I hope iT's as simple as that. But wouldn't a bad engine leak oil as well?
:dunno
I'll b free wed to take It in. I wish there was a friendly g35 shop that I can
Take mycar Into for any of it's problem besides the dealer in Toronto.
Old Apr 27, 2009 | 07:15 PM
A bad engine would consume oil.
Old Apr 27, 2009 | 08:40 PM
emorehs's Avatar
that happend to me before every cold start in the morning I had a leak.. I lift the car and found out the "O" ring from engine fan were the leak coming from..
Old Apr 27, 2009 | 11:47 PM
t7n7's Avatar
what you mean by the O ring from the engine fan? so its not my engine and its a minor fix? i know a bad engine would consume oil but correct me if i'm wrong, wouldn't there be a leak if the engine had like a small hole or broken seal to it? :S
can't wait til wednesday, going to get ANOTHER OIL change done just to make sure its not the filter.
Old Apr 28, 2009 | 12:36 PM
hg35x's Avatar
I had a similar leak. The rubber washer around the dip stick was shot. Replaced dip stick and it fixed the problem Check to see that your dip stick is seated.
Old Apr 28, 2009 | 04:07 PM
t7n7's Avatar
dip stick has a rubber washer? :S i thought it was just a peice of metal that goes inside where i can check the oil levels? I'll check out all of your suggestions tomorrow! thanks guys for your VALUABLE input so far...
Yesterday, after an overnight parking, no oil patch! (i take a picture everytime and compare).
I can't wait to do a comparison tonight, let it sit there for about 16 hours so far.
*crosses fingers* ...
Old Apr 28, 2009 | 05:17 PM
hg35x's Avatar
Not really a "washer", kind of works like a small "rubber cork" that seals the end of the dip stick. I have heard that if you run your engine without the dip stick in place oil will splash out. The "rubber cork" thing seals it.
Good luck!
Old May 2, 2009 | 09:08 PM
stickytech's Avatar
ive seen tons of oil filters leaking.especially quaker state ones
Old May 3, 2009 | 07:01 AM
Blue Dream's Avatar
I drove ttrank's car solo
Please tell me you have checked your oil before. If so you would probably know how it looks.
I had a very small oil leak on my car when I bought it as well. Took it to the dealership and they replaced the seal between the filter and the oil cooler. It had been damaged by someone overtightening the filter during oil changes. They also replaced the oil and filter. How much did this cost total you ask? $0 all covered under powertrain warranty.
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
itztwinki3
Aug 11, 2015 05:52 AM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
